4WD running problems
Old 12-04-2010 | 12:38 PM
cra1g's Avatar
cra1g
cosworth
Default 4WD running problems
Hi everyone,
Posted a thread some some weeks ago (4x4 cosworth spark plugs) regarding a misfire on my cosworth.
After reading the replies i got i made some changes to the car wich ive listed below.
New rotar arm
Distributor cap
Full lead kit
Grp A coil Pack
Genuine 071 spark plugs with gap set at 0.5mm for now.
I basicly thought the car was misfiring as when im driving along nice n steady i can feel the car spluter for afew seconds, then it will go back to running nice and smooth. Sometimes this happens regularly and sometimes now and again. More so when its warmed up.
It realy causes problems when this happens as the turbo comes in because its really wanting to pull but the revs just wont build up.
And i dont know why but its at its worst when i try n reverse onto my drive wich is on a small incline.
Can anybody advise me on what to look at next.
Getin abit p...ed off with it now.
Old 12-04-2010 | 12:45 PM
jon@work's Avatar
jon@work
do you have problems when the fuel tank is full ?
Old 12-04-2010 | 12:46 PM
martysmartie's Avatar
martysmartie
Check the phase sensor, more importantly the wiring inside the cap as these are prone to snapping and shorting out hence overfuelling, this shows itself more on boost like you say you have. May remotely be the CTS but it would be rough running all the time if this were the case they go out of calibration after a while.
Martin
Old 12-04-2010 | 01:55 PM
cra1g's Avatar
cra1g
cosworth
Not sure on the fuel tank as its not been full for a while.
Old 12-04-2010 | 02:49 PM
james kiely's Avatar
james kiely
have you changed your fuel filter latley craig?
Old 13-04-2010 | 08:50 AM
cra1g's Avatar
cra1g
cosworth
Good point james that has not been changed for 2 years as ive only done about 1500 miles in that time..
Old 15-04-2010 | 03:17 PM
silky16v's Avatar
silky16v
Get on That!
change all engine sensors and check wiring from cps & phase sensor as in check for whats called black wire (corrosion in the wire)
Old 15-04-2010 | 06:50 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
It may be an idea to check the 3 black multiplugs on the bulkhead just above the cam cover as these have been known to fuck about or even better, cut them out entirely and hard wire the loom. I did this on a mates car that was having all sorts of misfire faults and it cured it totally.
Old 15-04-2010 | 07:04 PM
akamob's Avatar
akamob
as above, sorted my misfire out been fine since.
wheelwizardrefurbs
23-09-2015 09:14 PM
kosienutter
31
22-08-2015 09:55 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
Zoggon
10-08-2015 10:39 AM
lockie
31-07-2015 10:03 PM
Quick Reply: 4WD running problems
