ABS problem - rear wheels locking up
Don't mention ze Vor
Right, my ABS light is on all the time, sensor resistance seems fine so I doubt it's an easy fix.
What's a lot more worrying: When I hit the brake pedal hard and quickly the rear wheels lock up Would be lovely if it was a drift slag but it isn't.
When I gently and progressively apply the brake, brake balance is normal, locking up the front wheels.
I had a similar thing ages ago on a normal 2.0 and it was the solenoids in the abs unit being fubarred. However on that car, the ABS light didn't stay on.
Could a faulty ABS control box also cause that kind of behaviour?
Check the brake fluid level. If it is OK, take the 2 pin connector off the brake reservoir and bridge the 2 terminals on the wiring loom. If the light goes out, get a new brake fluid level sender.
With the abs light being on, it is partially or fully disabled(the abs) this then would leave you with normal brakes, do you have the same pads on all four wheels, ie same rear as front ?
If the abs spots an anomoly it will illuminate the light, a rusty sensor disc can do it if a tooth is chipped and missing enough.
mine locked the rears up when my abs wasnt working,its dangerous when it happens leaves you lookin at the hedge for a moment. did you try the orange relay in the fuse box yet?
Ford did cock up a bit on the abs when this is duff, it can be either partially or fully disabled depending on the fault.
If a fault is sensed it will stay illuminated until it senses fault fixed.
Yes the rears do indeed lock up easily without abs functioning 100%, even when the abs is working, there is still way too much bias to the rear, as I've been sideways under really heavy braking, as rear nearside locked up!!, the "fault" only showed up under seriously heavy braking from speed, wheel locked, abs light came on 1/2 mile later went out and stayed out.
It has not done it since I recut some teeth on the rear sensor ring.
The abs system does not control the front rear bias.
JoeyBoyden
04-01-2024 03:36 PM
Red_bull
09-08-2015 09:34 AM
