Alloy bushes for inner track control arm mount?
Does anybody make an alloy bush for the inner TCA mount? I hate Powerflex bushes! And I hate trying to get these fucking arms into the sodding crossmember!
Charlie
Charlie
I have never seen these, but would be a doddle to make, am going to the metal suppliers on monday to price up alloy metal as interested in making a few bits myself.
![](http://i32.photobucket.com/albums/d37/charliemoseley/IMG_2084.jpg)
Charlie
Charlie,
Just rose joint them, you can buy a kit from rally design.....
![](http://www.rallydesign.co.uk/images/RD425.jpg)
U'd just need some spacers to match you crossmember and you'd find it easier to acheive your desired camber settings...
Dont use alloy in place of the rubber....
HTH
Ian
HTH
Ian
I was thinking about rose jointed adjustable TCAs but I can't use adjustable TCAs in the race series I'm in. I am allowed to use them if they are adjusted to the right position then welded.
Anyway, I got my arms on this morning via leverage:
![](http://i32.photobucket.com/albums/d37/charliemoseley/IMG_2119.jpg)
Charlie
Charlie
Alloy wouldn't be a suitable material here due to that amount of movement, they can be made in two top hats pieces easy enough, but there needs to be a sliding surface somewhere, maybe a bearing in the end or as said rose joint would be much preferable if allowed.
