the car shivers when drives backward...
When I drives backward with completely turned out steering wheel on my 4x4 cossie the car shivers with the frequency seems like equal to a turn of a wheels.
I did not hear sharp sounds, but not the fact that sounds are not present absolutely in this moment.
During any drive forward there are no problems.
Is that means I have a dead front outer CV joint? Or both of them? Or something else?
If i was you i would put the car on stands and start it up and do it the same as you have just said and have a good look under the car as its running and track it down that way. Iv done this meny times with my mates escort cosworth ..BUT USE GOOD STANDS AND HAVE SOME ONE TO HELP YOU AS ALL 4 WHEELS WILL BE GOING ROUND
Resident Wrestling Legend
it'll be the bushes as the car is designed to go round corners forwards ratehr than backwards
our buses used to do the same as everything is geared to the wheels rotating in one direction and not the other
whats happening is that the front wheels are scrubbing as they go round due to them not having the same loads on them as you get when you go forwards
so it's either the track control arm bushes, the bottom ball joints of the anti roll bar that is letting them run out of true
i don't think it's the cv joints winding up as they would probably break after a while and that would be very noticable
Or you suggest to prop up the car for levers?
OCD Victim
As Dojj said, it is the front wheels scrubbing against the road surface when on lock. My 4be used to do it getting on the drive. It was only noticable after I put the poly TCA bushes on as they hold the front end just that little bit tighter. All I did was to readjust the tracking slightly (very slight bit extra toe-in if I remember). It is still in spec. and does not do it any more.
OCD Victim
There is only about 10 minutes (1/6 degree) of adjustment tolerance on the toe alignment, so they have to be pretty precise. Mine is set slightly to the toe-in of the centre of adjustment figure.
slightly off topic, but i jus got my 1st cossie. Its a 2wd stg3, however its not set-up yet as its a fresh rebuild so its running just over 1bar boost..anyways, in this damp chilly weather its no bother to light the rear wheels up, when this happens i get a judder from the back (axle tramp..??). Is this common or down to worn bushes etc..cheers, Nik
it may be the diff and teh viscous lsd inside not playing properly, leading to the juddering
if it's coming in and out then that's one option
the others would be the diff mount, beam bushes and then, if they are originals, the rose joints/bushes in the arms
get someone to reverse the car on full lock while you watch
you will see that the bottom of the tyers will start to pull outwards and will look "tighter" on the rims than they normally would
and then, when you straighten the wheels, they will look "normal" again
You mean, I have no reason to worry, pal?
you should have no reason to worry as it's more of an issue with the 4wd cars than the 2wd ones as you have different front end geometry due to the front wheels being driven as opposed to the front wheels just going round
as long as it's ok going forwards then i owuldn't be overly concerened with it doing something funny going backwards
Stu @ M Developments
41
21-08-2015 06:47 AM
CabrioTurbo
01-08-2015 11:04 AM
