Engine build for 400-450 bhp
Old 03-08-2006, 09:47 AM
TurboShed
Cossiemodo
TurboShed's Avatar
Default Engine build for 400-450 bhp
So my engine is fucked, time for a rebuild.
Currently have T34.63, RS500 I/C, greens etc.
Want to go low compression with the rebuild so I can take the T34 over 400bhp on greys and ultimately, in about a year when I can afford it, get a T35/38 and go for 450bhp.
So what do I need for a low compression rebuild and what should I expect to pay?
Old 03-08-2006, 11:33 AM
Staffi
Staffi's Avatar
Opinoins differ, but a T34 with over 400 will be ringing its neck IMO....
If its 450 your after, just get a T38, or a nice GT30
Old 03-08-2006, 12:03 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Ok, for the moment forget the turbo, I'll stick with the T34 until I can afford a new turbo - for the moment the price of the engine rebuild is enough! I need suggestions on engine components:
Low comp pistons? Where/what kind?
Do I need a rebore? How much etc?
Other considerations?
Old 03-08-2006, 12:14 PM
Tangodeltasierra3
Tangodeltasierra3's Avatar
Buy the COSWORTH nagazine in Smiths and have an hours reading - look at specs of other peoples cars etc & price the bits up etc....Have fun!
Old 03-08-2006, 02:19 PM
TurboShed
Cossiemodo
TurboShed's Avatar
There's a magazine called "Cosworth"?
Old 03-08-2006, 04:27 PM
cossiegreg1
cossiegreg1's Avatar
its the performance ford COSWORTH edition its really good .if i were you,i would ring woodford garage motorsport 01803863958 and speak to simon(or any of the others ).thats what i did when i wanted a rebuild on mine.He didnt sell me stuff i didnt need.i just told him what spec i was looking for and he told me exactly what i should get.i got a good discount and it was there within 48 hrs.i cant go on about them enough, its a proper honest buisness who are not trying to rob you and just want to sort your car out for you.
Old 04-08-2006, 10:12 AM
lukeytheduke
lukeytheduke's Avatar
is there a massive difference between the t38 and GT30 as im having my car built to around 430bhp
Old 04-08-2006, 11:34 AM
Staffi
Staffi's Avatar
Price, YES, T38 will be fine for 430
Old 05-08-2006, 07:28 AM
space hoppers
space hoppers's Avatar
a turbo technics t38 is good for 470 bhp
Old 05-08-2006, 12:01 PM
rabmc
rabmc's Avatar
Mmmm this magazine sounds good , going to have a look today
Old 05-08-2006, 12:14 PM
Jay,
Sponsor
Jay,'s Avatar
when u get to it i would go the gt30 route chap at 450bhp it wont be having the tits rung out of it
Old 08-08-2006, 04:38 PM
cozzie4d
cozzie4d's Avatar
low compression 7.6:1 is enough for 450bhp I'd say.. (forged maybe)
mind the cilinderhead, since it affects your comp. 2wd or 4wd.
- get some h-section conrods,
- bolt it up fully in ARP
- balance/grind the crank
- use high pressure oil pump
- dont save money on thermostat, gaskets, waterpump etc.
that's what I did, the engine should be strong enough to hold about 450bhp (although I'm not going above 370bhp in the near future)
good luck
Old 09-08-2006, 06:56 AM
TurboShed
Cossiemodo
TurboShed's Avatar
TBH the money is all getting scary now, I'm thinking I'll keep the bottom end standard, was pretty happy with 350bhp anyway.
Old 09-08-2006, 01:55 PM
cozzie4d
cozzie4d's Avatar
then it'll do indeed..
Old 10-08-2006, 07:24 PM
Danny @ Enhanced Performance
Danny @ Enhanced Performance's Avatar
if youve got a 200 block i would long stud it rebore it go 7.5.1 comp ratio even 7.8.1 be fine arp bolts new oil pump rebuild head new guides etc bd14 inlet cam go up to greys and youl have a genuine 400bhp motor after a proper remap give me a buzz if you want a good price and more details cheers
Old 10-08-2006, 07:47 PM
Mr 19"
Mr 19"'s Avatar
Why go low comp and different rods? Standard rods are good enough! I,ve been running standard comp for 5 years and standard balanced bottom end with standard bolts without any problems. revs to 7800 rpm.
Old 10-08-2006, 09:04 PM
cozzie4d
cozzie4d's Avatar
I think it depends, if you got it all ripped open, why save a few hundreds of pounds..
it'll make your engine more capable and probably stronger..
allthough depends on your cashflow offcourse
Old 10-08-2006, 10:38 PM
theres no probs with standard rods at all but like said if your going to use new pistons you might aswell go lower comp as you can ad more spark to the map therefor getting more tourque and pistons will also last longer and you can always ad more power in the future as for bolts your very lucky to rev so high and not have probs its more a precaution than anything else
Old 11-08-2006, 05:34 AM
cozzie4d
cozzie4d's Avatar
I agree, because you hopefully don't want to rip it open again (soon)..
Old 11-08-2006, 06:20 AM
Mr 19"
Mr 19"'s Avatar
Yes. i understand your thinking! I was thinking of the driveability and fuel economy too. Here in sweden we have people running over 600 bhp with standard rods that are shot peened and have ARP bolts. How often do you here someone who has broken a standard rod? I don,t want to be cocky (wrong spelled?) just intrested to have a good discussion and see what you think over there! Another intresting thing is that we use high comp here in many engines. My friend is running 8,8 in comp with close to 600 bhp on regular fuel, and it works fine.
Old 11-08-2006, 06:28 AM
cozzie4d
cozzie4d's Avatar
I think it's definitely worth a discussion (without offense offcourse)..
Another reason why I went for H-section rods is that the std rods from my old engine needed new "bushes" (rings in the smaller side, don't know for sure how their called).
The problem is that renewing the bushes is an expensive job.
Just selling the standard ones + the price of renewing the bushes + a set of ARP bolts, was only 200 pounds cheaper then going for a complete new set alu/titanium Saenz H-section rods (shotpeened, incl. ARP bolts etc)..
To be concrete, I think it also depends on the quality of your current std. shapes, and if they need work or not.
Old 11-08-2006, 06:43 AM
Mr 19"
Mr 19"'s Avatar
Okay. Then i also would change rods if the difference in price isn,t more!
How much power do you think a standard rod with standard bolts can take? Intresting to see how you estimate them compared to us in Sweden!
Old 11-08-2006, 07:03 AM
gingeRS
gingeRS's Avatar
so whats the difference in prices between a
T34
T38
and a GT30
whats the respective power of each one?
cant find any turbo prices on the web
Old 11-08-2006, 11:11 AM
Tarren
Tarren's Avatar
T34
T38
and a GT30
Yeah i would like to know that two
Old 11-08-2006, 04:39 PM
DAN P
DAN P's Avatar
t34 about 600 -650 new
t38 1100 ish
gt30 1300 ish i think
Old 11-08-2006, 10:02 PM
Staffi
Staffi's Avatar
Agree DAN
JoeyBoyden
04-01-2024 02:36 PM
mgtkr1
107
06-12-2016 04:23 PM
SmudgerByName
52
28-07-2016 06:14 PM
IAN RS2k
18-08-2015 07:51 PM
knight19770
04-08-2015 12:36 PM
Quick Reply: Engine build for 400-450 bhp
