Sapphires electric rear windows
I have some problems fitting electric rear windows to my sapph. Should electric rear windows open as much as the manual windows?
The rear windows don't come down all the way due to the shape of the rear door, but no matter if they are electric or manual. You may have dropped a cog when fitting the electric mechanisim. You'll probably need to remove the mechanism and check that when the motor has reach the end of its movement that there are no more teeth left to run.
I've never had this problem so I'm only guessing, if any one knows any different then please correct me.
The motors move on the floor just fine but when I install them into the door they open window only about 4". I am not really sure that which motor is the left and which one is the right one. Should the engine itself point to the floor? Are there any differenties about electric and manual windows glass itself?
Had a SRI130 Vaux Cav that I converted to electric windows and the runners were different lenghts on the bottom of the glass
Didn't notice to start with,but deffo noticed when I put the window down and the glass fell inside the door!
3dr cossie
21
20-11-2015 05:00 PM
borboyous
22-08-2015 11:17 AM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
