Saff cossie 4x4 plugs
Mine is only running stage one, but it kept blowing no1 spark plug with NGKs, so I changed to PJ Motorsports £25 set, no problems at all since then, hope this helps.
About the same stage as you, but i use it only on track, so some cold apgr701c's gapped @ 0,65mm for me
look also on here
https://passionford.com/forum/viewto...ighlight=plugs
look also on here
Originally Posted by p_jay78
I do...
On my old stage 3 they were gapped down due to the boost blowing out the spark
are these the plugs thats listed for escort cossies ,heard a lot of peeps mention that before on the 2wd saffs ??
I have the ngk irridium (spellin ) plugs but they did cost me near £60 odd quid thereabouts and have been fine so far but are exspensive for how a cossie a can eat plugs lol
.25 or something rings a bell? Not quite sure from memory. I was running about 28psi boost
new plugs about every 2000 miles though. At least they were cheap!
I do...
Originally Posted by cossie330
Hi guys have just fitted QC57C plugs on recommendation but was told to expect lumpy tickover is this true and has anyone else had this ?
Its a very good plug mate so if you can put up with the lumpy start its worth it, alot of people go for c59`s but i`ve been told that there not that good for a 330/350 brake cossie, more a 220 brake rst engine kind of plug
Use platinum tipped Motorcraft PP8's in my cossie, running similar spec as you.
DixieTheKid
23-07-2023 10:16 AM
Anutternutter
21-08-2015 06:07 PM
mrmann
20-08-2015 11:24 PM
