2.5 v6 manifold gaskets
Yea I've got the tick and its pissing me off I've tryd hydrolic lifter cleaner, engine flush and oil change also took it to a garage and had new fan belt wheels fitted as they thought it was bearings ticking but no it still remains!!! I had it on some ramps weekend and the rear manifold is leakin a little bit of oil which to me is the problem and creating the tick, apparently they can come lose and just need tightening up but I think replacing the would be better! It's defiantly not the head gasket 100%
Spelling Club King!
Not on the V6. There's a weak point on the gasket which vents to atmosphere. There will be no water, or oil loss, and a barely perceptible loss of power. It will cause a very similar sound to the exhaust manifold blowing, but can go on for miles without getting worse, or causing an issue.
Hence why I said be very sure it's the exhaust manifold before attempting a replacement. I'd want to be feeling the gas actually coming out of it before I considered pulling the engine apart.
I've bin told on the v6 engines when the head gaskets gone your water will bubble the odd bubble is normal but when it bubbles constantly then that's the air escaping
Spelling Club King!
Not saying that's what you've got - but just google 'Mondeo V6 head gasket' and you can see the amount of people who have had the issue.
Skint V6 owner
When the HG went on my ST24, I only noticed because I was under the car looking at the state of the manifold studs in preparation for switching them over to headers.
On the rear bank near to cylinder 3 I saw a trail of oil coming down the block which was definitely coming from the join between the head and the block (not high enough for the manifold). I checked the schematics and did a bit of research, and sure enough there is an oilway and weak gasket point right there.
I took it for a 400 mile round trip without problems then decided I'd used all my luck up and fixed the HG myself, I figured it would be much easier to fit the new headers to the heads with them off the car (this was a VERY good idea now I've done it since there was one stud on each head that was proper rusted in and needed heat and a lot of room to turn it out which would have been near impossible with the heads on the car still). When I got the heads off the scorching to the head and damage to the gasket was evident right where I thought it would be.
I lost no water and no excess oil (though it was leaking, it was very slow and not noticeable), and power remained normal. I didn't bother compression testing it because I wasn't in denial, I knew the HG had gone
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
caprixpack
25-09-2015 07:53 PM
