1.8 Zetec 4-2-1 or 4-1 exhaust manifold
Old 07-11-2007, 01:31 PM
PeterRST
Don't mention ze Vor
PeterRST's Avatar
Default 1.8 Zetec 4-2-1 or 4-1 exhaust manifold
Hey there,
one of my mates is looking for a 4-2-1 or 4-1 exhaust manifold for his 1.8 16V Focus. What's the best place to buy and is it possible to fit one and still maintain the cat? We're from Germany so we have to keep it (emissions test every two years).
Any help is much appreciated!
Old 07-11-2007, 05:39 PM
Wardy257
Wardy257's Avatar
It is not worth the effort on a standard 1.8 ZETEC as it will do nothing. Save your cash for something that will have a positive affect.
Old 07-11-2007, 07:26 PM
PeterRST
PeterRST's Avatar
It's not standard. It's got a induction kit and a full s/s exhaust.
Chip and some funky cams to follow...
Old 07-11-2007, 10:32 PM
Wardy257
Wardy257's Avatar
Induction kit and exhaust will do nothing but make noise. There is no point fitting cams as the standard cams are good for 155+ bhp it is the mapping and poor inlet manifold that is holding the power back.
Tunning the ZETEC is not like an old CVH. You need to do everything in the right order or you will end up spending a lot of Łs for each BHP. So far you have spent a lot for nothing!!!!
Old 08-11-2007, 08:34 AM
PeterRST
PeterRST's Avatar
I've read through your web site a bit Wardy.
So basically what you're saying is, that I'd need to put on some throttle bodies and any other modification won't make sense until i get the "breathing" right?
Old 09-11-2007, 02:56 PM
Wardy257
Wardy257's Avatar
Throttle boddies are the ultimate but you can buy and/or adapt other inlet manifolds. A common mod is the Rover Turbo inlet as the spacing is nearly spot on, you just need to make an adapter plate. You can use the Rover turbo injectors, TB etc and add an aftermarket ECU. It appears to be good enough to flow enough for 170+ bhp.
Some people use the ST170 inlet and motorbike TBs but that is mainly in RWD applications were space is not so much of an issue.
The problem is the standard inlet maxes out at around 150bhp so no matter what you do with cams, mapping etc you will only get 150 bhp.
Jay robo (28-11-2020)
Old 05-06-2010, 12:57 AM
jonyb4
jonyb4's Avatar
wardy, your being bit a gammon slipper aobut it aint you? theres plenty of power to be had from the 1.8 with out going mental like TB's and rover inlets
ive seen plenty reach 150bhp without spending more than Ł500, im planning on doing the same with the 1.8 in my mk4 fez
id say give the four branch a go, it will free up the engine and allow it to rev freely without strangling it, ive had mates tell me it sounds better and not screaming at you as you hit 5k rpm
burton power do ones from Ashley but theyre close to Ł200, i know of cheaper but im trying to find them myself, heard of thema round Ł130, not sure about german retailers, but imsure you can get them posted oversea's
try and get a H.O inlet and 2.0 cams in it, then if costs aint an issue remap it after these, then it should see past 150bhp with a four branch easy, the focus's plastic inlet manifold is a bit small compared, if you cant get hold of a H.O cast inlet try the 2.0 mondeo plastic inlet if the focus brake link bar allows, i know fiesta ones dont...
on mine im using focus ST170 spark plugs, im after megnecor leads, coil packs on these are meant to be solid enough according to ian howells
ive got a decat back Stainless exhaust and induction kit with ERST charge carrier and H.O inlet, getting 2.0 cams soon and after a early mondeo 2.0 ecu (pre pats for obvious reasons) then a four branch, hopefully all this will see close enough to 150bhp
Old 05-06-2010, 08:31 AM
pee vee
pee vee's Avatar
Have a look at the ST170 exhaust manifold.. That's what I used on my old 2ltr zetec
Needs a little bit of work to match it to the rest of the exhaust.
They are a 4-2-1 design and pretty equal length etc.
They were mega cheap when I did it about 6 years ago, and it's ford parts so the quality is good. If it makes a difference or not is another matter. Lol
Pic
Old 05-06-2010, 06:45 PM
jonyb4
jonyb4's Avatar
cheers mate, i have no idea where to look to get one of these, nto to mention the prices
Old 05-06-2010, 09:51 PM
pee vee
pee vee's Avatar
Your local ford dealer!
Old 06-06-2010, 01:12 PM
jonyb4
jonyb4's Avatar
lol ill have a peek next time im in, cheers man
Old 06-06-2010, 07:15 PM
2007 btw
Old 06-06-2010, 08:48 PM
pee vee
pee vee's Avatar
Oh yeah. Lol. Didn't look at that! Lol
Old 06-06-2010, 11:57 PM
jonyb4
jonyb4's Avatar
lol yea i found this on google by searching 1.8 zetec 4-2-1, and i only seen the date after i posted :P
Old 14-12-2010, 10:24 PM
Focus333
Focus333's Avatar
Originally Posted by pee vee
have a look at the st170 exhaust manifold.. That's what i used on my old 2ltr zetec
needs a little bit of work to match it to the rest of the exhaust.
They were mega cheap when i did it about 6 years ago, and it's ford parts so the quality is good. If it makes a difference or not is another matter. Lol
pic
when you said needs a bit of work to make fit, would the st170 flexipipe do the trick? I have 2000 plate 1.8 focus and want to stick one of these on myself.
Thanks
Old 15-12-2010, 12:40 PM
hineho87
hineho87's Avatar
Thanks
i did this on my 1.8 and it made a noticable difference.
The parts you need are:
- st170 manifold
- st170 cat
- st170 flexi
- St170 gaskets
- st170 dipstick tube (Ł10 new from ford)
- ST170 ps pipe (Ł90 new or Ł30 2nd hand)
Only things you need to modify are:
- either bend ur existing power steering pipe at the side of the manifold to the front of ur engine bay (or buy the st170 one)
- replace you dipstick tube (can use you existing dipstick) as it now moves postions to in the middle of the new manifold (or again you can bend it but not worth it for a tenner
- black off the 2nd lambda sensor and move to the neck of the cat as it otherwise it rubs on the drive shaft
Hope this helps, pm me if u need any more info.
Matt
Old 15-12-2010, 10:04 PM
Focus333
Focus333's Avatar
- st170 manifold
- st170 cat
- st170 flexi
- St170 gaskets
Matt
Thanks a lot Matt just the info i needed, only difference is im planning to do de-cat until i can afford a sports cat. Not sure how that will effect my engine management light from coming on because it wont be reading a co2 emissions after the CAT.
Do you know roughly how long the ST170 flexpipe is?
As far as i can tell if i put just the ST170 manifold theres only going to be around a 10-12 inch gap between the bottom of the manifold joining to the the rest of the system. I want to either put the ST flexpipe in it if it will fit nicely or weld a peice in until i cant get the rest of the system sorted.
Again thanks and if you have any info that might help with what i just said let me know.
Joe
Old 15-12-2010, 10:26 PM
Focus333
Focus333's Avatar
What changes do you need to make for the ST170 inlet manifold to fit? Ive found one with all the injectors and fuel rail and wires, is it just a simple swop over job or is the a lot more tech required?
Thanks
Joe
Old 20-12-2010, 07:05 AM
hineho87
hineho87's Avatar
Thanks
Joe
I dont think the st170 inlet manifold fits without modifying it, also when i asked this i was told there was no point fitting it as i wud get no gains. But never tried it to know for sure
Old 20-12-2010, 07:08 AM
hineho87
hineho87's Avatar
Joe
Tbh m8 you can pick up the std st170 cat which is a sports cat 2nd hand for the same prive you will pay for a decat so in my opinion i wud say it was worth the risk. Also some people who have st170's say they actually have lost power?!?
Not sure on the sizes m8 as now it is all fitted to my car and its not the weather for checking lol. If you fit the cat/decat and then the flexi from the the st170 it will be the rite length to meet you std catback system
Old 21-12-2010, 12:27 AM
Focus333
Focus333's Avatar
Ahright yeah i get you, i might just get a 4-2-1 of eBay i found that will fit straight on mine as it is now, decat then get sports cat put in at local gargare.
One thing i did want to ask is whats the deal with people sticking ninja carbs from bikes in? I hear you get great results from it but dont know the risks or how its done etc, anyone got any info on that? Let me know
Ta again for the manifold info, cleared things up for me no end.
Old 21-12-2010, 12:36 AM
phil_focus
phil_focus's Avatar
the bike throttle bodies route is supposed to be a cheaper route than jenvey but requires more fettling/bodging to fit. you will also need to wire in an aftermaket ecu and loom and have it custom mapped.
Old 22-12-2010, 07:03 AM
hineho87
hineho87's Avatar
+1 ^^. Depending wot route you go down it can start getting into the couple of Łks. A lad i know had 210 or 230bhp (cant quite remember) from his 2.0 focus running on ITBs. But the power is mostly at top end so has to be driven harder to get the power. You will also need look at upgrading the brakes as well to something like the st170 set up.
Matt
Old 22-12-2010, 09:36 PM
hogdog
hogdog's Avatar
My 1.8 made 120bhp and 126lb/ft on TOTD's very accurate rollers....it had....
An OBX 4-1 manifold and a Milltek cat-back, nothing else.
That's quite a big improvement on the standard figures for those mods.
My standard 2.0 made figures virtually identical to the factory figures on the same rolling road.
Old 14-06-2018, 09:54 PM
Dave Bartley
Dave
Dave Bartley's Avatar
Default About to attempt
- st170 manifold
- st170 cat
- st170 flexi
- St170 gaskets
Matt
was the back end standard 1.8 or did you have upgraded middle and rear section?
Old 20-06-2018, 08:05 AM
Dave Bartley
Dave
Default Load of rubbish
im doing this mod now and have found that You can not just fit manifold cat and flexi to the standard 1.8 the is an inch diffrence in diameter for the pipes! You can however fit the entire st170 exhaust! This is now what i have to do to make this mod work on my 03 focus mk1 mp3 1.8i zetec blacktop.
jessie_rs
62
06-08-2019 09:27 PM
talon1
15-09-2015 10:27 AM
Si B
12-09-2015 06:49 AM
BRAM
08-09-2015 07:11 AM
little bram
07-09-2015 11:59 AM
Quick Reply: 1.8 Zetec 4-2-1 or 4-1 exhaust manifold
