S2 CUTS OUT THEN BACKFIRES
Old 18-06-2004, 04:35 PM
Tony Rs
Ebony black Sapph Cos
Tony Rs's Avatar
Default S2 CUTS OUT THEN BACKFIRES
CAR IS CHIPPED ITS GOT PACE INT, DV, MONGOOSE EXH
WHEN IT COMES ON BOOST IT CUTS OUT THEN BACKFIRES SINCE ITS BEEN DOING THIS WHEN I SWITCH THE CAR OFF IT WONT START AGAIN ONLY IF I JUMP START IT ANY HELP WOULD BE MUCH APRECIATED!!!!!!!
Old 18-06-2004, 05:04 PM
turbo.jon
turbo.jon's Avatar
It sound like its over boosting as thats what mine done before it went bang
Are you sure it is chiped and what boost is it running?????not to sure on why wont start does it turn over
Old 18-06-2004, 05:15 PM
Tony Rs
Tony Rs's Avatar
ITS GOT A TURBOSYSTEMS CHIP IT WONT START COS THE BATTERY IS FLAT AS SOON I SWITCH OFF DONT UNDERSTAND IT M8
Old 18-06-2004, 07:46 PM
turbo.jon
turbo.jon's Avatar
Alternator or battery f#*ked then!!!mine was chiped but would only let me run 15psi it must be a stg 1 chip.i turned boost up and it boosted cut out then bang blew my engine too just see if anyone else have any ideas
Old 18-06-2004, 07:50 PM
CarlRsT
CarlRsT's Avatar
Have u checked your alternator????? Mine went bang everything cut out then it jump started???
Old 21-06-2004, 07:43 AM
Tony Rs
Tony Rs's Avatar
ILL TRY THE ALTENATOR AND A NEW BATTERY M8 THANKS FOR ALL THE HELP
ILL KEEP YOU POSTED.
Old 21-06-2004, 10:16 AM
adamS2RST
adamS2RST's Avatar
I had a similar problem, is it putting any kind of smoke out the back, mine was a fucked ecu. Replaced it and was ok
Old 21-06-2004, 10:57 AM
jodyhoare
jodyhoare's Avatar
it is def the alternator id say m8 had the same on the way back from pompey on the motorway!!
Old 21-06-2004, 04:59 PM
CarlRsT
CarlRsT's Avatar
Mine went bang down the m6 @ night . . . . . was driving with no light then it gave out a few loud bangs and died Lucky I was by a service station
Old 21-06-2004, 05:50 PM
jodyhoare
jodyhoare's Avatar
mine was @ nite to we ended up doin bout 8 miles in the slow lane no lights or anythin till eventuarly she gave up!! good old fords!!
Old 22-06-2004, 04:41 PM
Tony Rs
Tony Rs's Avatar
FITTED NEW PLUGS WAITING FOR NEW ALTENATOR ILL KEEP U POSTED AGAIN THANKS FOR ALL THE HELP LADS.
Old 22-06-2004, 09:21 PM
CarlRsT
CarlRsT's Avatar
Old 23-06-2004, 04:32 PM
james_birch
james_birch's Avatar
well mine started playing up today!...was on way home down a12 racing a reni 19 16v..(which i whooped!)
and pulled over into my juntcion put foot on clutch then went to pull off and felt like i hit a wall then bang!...out the xzorst!....
might have been due to the extreme lack of fuel and my fuel gauge not working right!.... hasnt done it since i filled up!
Old 06-07-2004, 08:36 AM
davie0146
davie0146's Avatar
i have the exact same problem
the car dies like it hits a wall, then wont start unless jumped, the battery gets very flat. tried the ecu its getting power and all that stuff, im going to try a fuel ecu next.
bloody cars!!!!
timsrs
13-11-2018 11:48 AM
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
Fudgey
21
30-09-2015 06:19 PM
cossirob
16-09-2015 07:39 PM
Quick Reply: S2 CUTS OUT THEN BACKFIRES
