Series 2 escort bolts MISSING !!
![Angry](https://passionford.com/forum/images/icons/icon8.gif)
Hi guys.
This is a bit of a random thread start but I have got a problem I hope someone can help with.
I'm currently in the middle of rebuilding my series 2 ERST I've stripped out the engine and stripped it right down to a bare block.
I put ALL the bolts in a box which some NUMPTY at my work has THROWN AWAY!![](https://passionford.com/forum/images/smilies/angry.gif)
this has left me very much in the S*#T !
I wondered if anyone can give me a list of ALL the bolts for the engine, clutch, flywheel, bell housing, starter motor, mounts ETC ETC ETC. Or even more of a stretch can source a set
I know this is a LONG SHOT.
I hope someone might know some bolt sizes etc though. Any help is greatly appreciated thanks peeps
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
If it was stripped down to the block, you wont be re-using headset bolts etc anyway. So at least you know you dont have to buy some bolts because someone threw them away?
Is he/she paying for the replacements?
This is going to cost alot of money to replace..... Have you tried YWK parts(online) for all your NOS bolts etc for FORDs?
http://ywkparts.co.uk/shop/category_...aram=cid%3D%26
These are different links to different areas.
I might just have all the bolts for a cvh turbo I stripped.
Things like sump bolts, main bolts, oil pump bolts.
You would need new rod bolts and head bolts.
Thanks for replying to this post people.![Top](https://passionford.com/forum/images/smilies/smile011.gif)
No-one is taking responsibility at my work for 'losing' the bolts...very frustrating.
I've got an MFI 1.6 cvh turbo. I've got a few bolts for the top end etc and got main bearing cap bolts. New head bolts, new con rod bolts. New sump bolts. Most of the head is built up manifolds etc but mainly missing thermostat bolts, tensioner bolts, flywheel bolts, clutch bolts. Bell housing bolts etc etc. I was just after if anyone's got some sizes of bolts etc?
I've made a slight list of some bolts IE
thermostat M6 40mm x3
Clutch plate M8 14 mm x6 (10mm bolt head)
Distributor M6 X3
Alternator M8 X4
Distributor M6 X3
Alternator M8 X4
borboyous
22-08-2015 11:17 AM
