Head spec's (CVH)
What have you had done and where from? has anyone ported there own and did there own work. Ive been reading up on it and want to see what your views on it ie port sizes, springs,valve size and would like to see some pic's of work you have had done. have you seen good results.
thanks
lee
thanks
lee
thanks rob mate ive got a bv cylinder head developments head on atm but its holding me back as the ports are'nt as big as i thought. did you do yours?
Here you go mate and yes I did mine, but my ports are deliberately on the small side as I wasn't going for massive power.
Good luck mate!
http://https://passionford.com/forum...y-started.html
Good luck mate!
Big ports do not mean big power. Most "home ported" big port heads do not make the big gains that most think. The largest restriction with a CVH is the factory inlet manifold.
Ps I did try to pm you a pic of my map but i dont know how to copy it to send it to you
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
The CVH port is a tricky port to get right. It has an offset port shape which has issues.
One can make the entire port area larger, but without a flow bench to test results of material removal one can easily remove material that makes the flow worse.
This is the trouble with high power CVH builds - the head flow.
CNC heads does a pretty good job with CVH stuff. We got similar flow results with a smaller port - which means higher velocity.
We got to 200cfm @ 28" and 0.450" valve lift. Plenty of flow for well over 175 HP normally aspirated.
I hope to see your map someday.
perry
perry
