Overheating ?
Old Feb 12, 2012 | 03:45 PM
Omitsean's Avatar
Omitsean
Default Overheating ?
Need help pls have an escort Rs turbo in a cab seems to be getting a bit hot a pipes on right hand side of engine swell up then I undo the water pot and it goes down again have a bit of cream under oil cap but none on dip stick also no hot air in car pls help some one
Old Feb 12, 2012 | 03:50 PM
55rsturbo's Avatar
55rsturbo
sounds like head gasket mate
Old Feb 12, 2012 | 03:52 PM
Omitsean's Avatar
Omitsean
Does not have any other problem when driving or on tick over tho still runs sweet
Old Feb 12, 2012 | 03:58 PM
martysmartie's Avatar
martysmartie
What temperature is it running at?
As said for the pipes to be swelling up and with the presence of "mayonaise" I suspect the head gasket, does it loose any coolant?
Martin
Old Feb 12, 2012 | 04:01 PM
Omitsean's Avatar
Omitsean
No does not lose any water at all and the temp never gets to red fans kick in way before and takes about 45 of town driving to get that hot
Old Feb 12, 2012 | 04:04 PM
martysmartie
Then it's not the HG!
Sounds like the thermostat, this would also explain no heating, which was my other thought initially!
It does not explain the "swelling" issue, however!
Martin
Old Feb 12, 2012 | 04:07 PM
Omitsean's Avatar
Omitsean
Put a new one in today and same problem the big pipe that goes in to it is one that swells going to give it a try with out thermosti tomorrow and see what happens
Old Feb 12, 2012 | 04:19 PM
55rsturbo's Avatar
55rsturbo
does it bubble up in the exspansion chamber as soon as you start it from cold.if it does probably head gasket
Old Feb 13, 2012 | 11:38 AM
Rogeyboy's Avatar
Rogeyboy
Sounds like a blockage somewhere to me...
If the pipes are swelling up and theres no hot water going to the heater matrix...
Check the pipes that go through the bulkhead into the car, do they have hoses attached?
Old Feb 13, 2012 | 11:39 AM
Rogeyboy's Avatar
Rogeyboy
How often do you drive the car, if used on short journeys they can get abit of cream under the oil cap, if its literally only a smidge then i wouldnt worry!
Old Feb 13, 2012 | 12:14 PM
Omitsean's Avatar
Omitsean
Just had rocker cover off and not much under it the pipe when you look on the right coming out of rocker is gunged up but dip stick is still fine and car still runs fine too
Old Feb 14, 2012 | 07:32 PM
johnnysash's Avatar
johnnysash
Blocked pipes or rad or heater matrix I would say. Flush it through with a hose pipe. It won't cure it 100% but will give you a chance
Old Feb 14, 2012 | 07:36 PM
Omitsean's Avatar
Omitsean
Thanks will give it a try tomorrow
Old Feb 17, 2012 | 08:32 PM
bigkev's Avatar
bigkev
i had that problem with mine mate, actually blew the hose of at radiator, pipes were solid, took head of cleaned block n head faces, replaced them with same multilayered gasket. torqued up, problem solved, just bite the bullet, will take you all off an hour n 30quid for new gasket, p.s used an oil stone to clean of block some wd40
Old Feb 17, 2012 | 08:57 PM
pat11's Avatar
pat11
hi, had same prob with one of my rs turbo's, changed head gasket & thermostat, turned out to be a blocked heater matrix. hoses bubbling up & bursting,
solved prob by removing hoses going to matrix & blowing air pressure jet through matrix.
be careful to hold open end of hose away from your face, or you will get a face full of gunk or in your eye. then flush through with a hose. hope this helps.
pat.
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Ade
Feb 8, 2007 05:11 PM
kurdt5
Jul 17, 2006 03:01 PM
fiestaturbo1984
Feb 19, 2006 03:51 PM
woodz77
13
Nov 6, 2005 03:02 PM
