Stainless Lambda Boss
Old Dec 19, 2011 | 06:13 PM
Mids_s2's Avatar
Mids_s2
Default Stainless Lambda Boss
Would I be able to weld a stainless boss into my cast elbow or will it crack?
Thanks Ben
Old Dec 19, 2011 | 07:01 PM
paul-h's Avatar
paul-h
Cast to cast has to be welded by correct procedure as you will probably know, not too sure about stainless to cast though! Depends how it's done and what method you use.
Old Dec 19, 2011 | 07:06 PM
Turbosimpsons's Avatar
Turbosimpsons
You'd probably be better drilling and tapping it.
luke19790_3's Avatar
luke19790_3
weld it lower down, on the exhaust
Old Dec 19, 2011 | 08:06 PM
Mids_s2's Avatar
Mids_s2
Good thinking I may drill and tap it, as a hole has to made anyway, maybe a bit over kill drill it tap it then tack weld it with mix metal rods.
Thanks Ben
Old Dec 19, 2011 | 08:15 PM
studabear's Avatar
studabear
Fit it in the down pipe. much simpler
Old Dec 19, 2011 | 08:21 PM
Mids_s2's Avatar
Mids_s2
May have to yet.
Cheers Ben
Old Dec 19, 2011 | 08:37 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Sorry to hack thread but is there a preferred/optimum location for the lambda on a yb downpipe?
Old Dec 19, 2011 | 09:19 PM
luke19790_3
on the cvh i think it needs to be near the sump
Old Dec 20, 2011 | 08:37 AM
Mids_s2's Avatar
Mids_s2
Im not 100% but think the closer the turbo the better the quicker it will warm up and more accurate it will be, think the T34 had a lambda boss cast into the exhaust housing?most use the downpipe just after where exhaust joins turbo.
Thanks Ben
Old Dec 20, 2011 | 10:17 AM
Rob_DOHC's Avatar
Rob_DOHC
No mate, wideband lambda's don't need any where near the heat narrow band sensors do. The higher the hear, the lower the sensor life. I have mine fitted at about sump level, however other still fit them further back with good results.
Delay is minimal and you won't gain anything from mounting it on the elbow other than short sensor life.
An EGT sensor on the other hand could go there.
Rob,
Old Dec 20, 2011 | 01:04 PM
Mids_s2's Avatar
Mids_s2
Ok cheers I'll put it in the downpipe.
Old Dec 20, 2011 | 02:53 PM
chaffe's Avatar
chaffe
Turbocharging Technician
or make a sample pipe for going up the lum if your just using it for tuning
Old Dec 20, 2011 | 06:51 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
run lambda in down pipe, just account for the few milliseconds delay.
i run mine behind he sump on the sytsem on the zetec turbo.
Old Dec 21, 2011 | 07:07 AM
Rogeyboy's Avatar
Rogeyboy
Mine behind the sump too, mild steel bung in a stainless system - not ideal for strength but it works and will do until i get a 3" system and stainless bung!
My Innovate WB gauge heats itself for 20secs or so before taking any readings, also Innovate state that it should be mounted just before the backbox for optimum sensor life!
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
rsguy
44
Sep 29, 2015 03:29 PM
