boost problem
Old Mar 27, 2011 | 10:49 PM
ajh_91's Avatar
ajh_91
Default boost problem
hi all.. im new here, im always reading up on the threads people write but this time i thought id actuall join and write my own problem with my series 2..
anyways to the subject.. my car ust to boost to 1 bar then a second later drop to only 0.5... when i toke the actuator off it was about an inch back from the pin it clips over.. so wat the've done is pull the actuator arm out to fit onto the pin.. is this wrong ?? .. i had a spare actautor from my frst and put that on so it was as short as possible but so i didnt have to pull it atall.. took is for a test drive and still only 0.5 bar.. then i shortened the actuator an inch as it now peaks at 1.5 bar and drops to 1.0 bar.. confused?
Old Mar 27, 2011 | 10:55 PM
tiny2white's Avatar
tiny2white
shortening the actuator arm is called pre load and needs to be done properly to suit the engine/chip set up,
the shorter the arm the more boost you will see, be carefull messing with it if you dont know the safe running boost range on the chip
Old Mar 27, 2011 | 11:01 PM
ajh_91's Avatar
ajh_91
well i know the ecu have been chiped with the 195 chip, but is it normal for it to boost to 1.5 then drop of to 1.0 and hold there ?
Old Mar 27, 2011 | 11:42 PM
MO' BENT RIMS's Avatar
MO' BENT RIMS
1.5 bar on 195 chip is too much i think imo!!! before u blow it up turn it down mate to 14psi max. or just take it to a tuner and let them set it rather than u blowing your engine!!!for the sake of a actuater
Old Mar 28, 2011 | 12:05 AM
Chopshop85's Avatar
Chopshop85
Actuator could be a bit worn. Mine struggled to hold boost before it was replaced.
also 21psi is alot of boost, wind that back down and get it to a tuner.
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
