-31 actuators
-31 actuators
Can someone explain to me why i would need one and would my car benefit from having one ?? Ive got a standard turbo as far as im aware , chipped ecu , piper cam , airtec frount mount intercooler , full mongoose ! At this spec do you reckon id need one ?? Oh and who does the best one ??
Thanks in advance
Thanks in advance
I believe the -31 has a lift pressure of about 8psi without pre load and a -34 has lift pressure of 14psi.
They operate using a spring which over time will weaken and not hold the boost pressure leading to a drop in performance.
You will probably be replacing like for like with a -31. I would use the Garratt version supplied, amongst others, by msd.
http://www.shop.motorsport-developme...ator-222-p.asp
Just had a look. This would be fine. I think you can get some discount off that if you read the ads on the site banners for msd.
saff is working!!!...atm
Thanks in advance
Thanks in advance
Thanks for the replies fellas , very helpful !
Its not that ive been advised to get one , its that im restoring the engine bay and engine ! As im going to be stripping down the turbo and repainting both the turbo and manifold , i noticed that the actuator looked a bit buggered so thought if i was to replace it i might aswell go for a modified one like the -31 ! Good plan ???
Thanks for the replies fellas you've been really helpful
Its not that ive been advised to get one by anyone . Its that im restoring the engine bay , including engine and box and ancillaries . As im going to be doing the turbo while the engine is out i noticed that the actuator looked buggered ! So i thought if i was to replace it i might aswell go for a modified one like the -31 . Good plan ????
Little bit of advice. There isn't a paint on the planet that will whithstand the heat of a turbo. Any paint you put of WILL flake off within a week. Ceramic coating or heatwrap is the only effective cover.
other than that yeah, a -31 actuator is a straight swap and doesn't have any adverse effects, just positives which is quite rare for a modification
JK12
33
26-04-2021 12:09 PM
