B&M fitting and a few questions
alright chaps.
I have bought a b&m off rs mark should be here 2moro, its second hand so doesn't come with instructions. How do i go about fitting it ? My old selector isn't fitted on the car atm so its out ready to be changed for the b&m .
As far as I'm aware the B&M kit only contains the selector its self and a small bearing is that right ?then i use parts of my existing selector .... How do i go about fitting it ? is it self explanatory once i have removed the underside of my old selector.
Forgot to add that my existing shifter has a pushdown revesrse will this make a differenc ?
Thanks Conor.Rst
Thanks Conor.Rst
Recived my shifter today, looks nice. Only problem is that the retaining clip seems to have been snapped in half at some point. Will this cause problems ?
![](http://i89.photobucket.com/albums/k211/conorneilly/DSCF4091.jpg)
![](http://i89.photobucket.com/albums/k211/conorneilly/DSCF4094.jpg)
Thier is no push down on the bm for reverse mate what box have you got ?
fitting is straight forward remove all the springs etc under the old shifter & just attach the bm shifter to the connecting rod then refit the cover
you will need a new circlip though
i done mine with the rods still attached to the box so i didnt have to adjust
also get some rubber gromments or something before you bolt it up to the floor
as mine made a hell of noise with vibrations
not very good at explaing or spelling
but hope its helped
the difference is day & night
but hope its helped
Conor - thats my old B&M, Mark brought it off me. The "c" clip im not sure if it should be bigger but thats the same size as when i had it, just use some long nose pliers to squeeze it right on.
borboyous
22-08-2015 11:17 AM
