conversion MFI to EFI (MS2-Extra) problem run engine :((
Old Nov 1, 2010 | 10:53 AM
red_spider's Avatar
red_spider
Default conversion MFI to EFI (MS2-Extra) problem run engine :((
hi all
I bought the RS Turbo engine and installed in my Orion had trouble with KE-Jetronic and it was decided to replace it with EFI, but emerged out of adjustment problems please help solve the problem
my configuration
Injectors 190cc
standart cams
EDIS
O2 Sensor - INNOVATE LC-1
MegaSquirt-II v3.0
firmware - ms2extra_2.1.0_release
My settings Ford_RS_Turbo.zip
I have two weeks with the settings without success
Table VE and Spark Advance Table
I found this forum
screen setting:
what is the problem? help please.....
Old Nov 1, 2010 | 04:10 PM
Karlos G's Avatar
Karlos G
Balls Deep!
There are a few things I would change...
AFR table is too lean around idle/cruise, and too rich everywhere else.
Your TPS AE is way too much.
Your TPS Threshold is way too small and will be cutting in without throttle input.
Your injectors are far too small for running any sort of real boost, maybe around 10-12psi max.
Your idle control valve frequency should be *4 not *2 or you will here it 'buzzing' with the ignition on and car not running.
But... what exactly is the problem you are having?
Old Nov 2, 2010 | 07:35 AM
red_spider's Avatar
red_spider
thanks for the help
is it a problem and I do not know what the problem is
checked the injectors inject
Spark is available on all cylinders
but the car does not respond ...
there were several shots and all: (
Old Nov 2, 2010 | 07:54 AM
chaffe's Avatar
chaffe
Turbocharging Technician
does it not start at all? has the ecu been modified internaly to run edis? if it injects and the edis is live then it will def run regardless as the edis will always be stuck at a dead 10deg if no advance signal is given from the ecu. Does the ecu show rmps when cranking? Need a bit more information mate.
Old Nov 2, 2010 | 08:00 AM
chaffe's Avatar
chaffe
also are you using the std ford flywheel pick up, or have you bolted on a 36-1 toothed wheel?
Old Nov 2, 2010 | 08:51 AM
red_spider's Avatar
red_spider
yes std ford flywheel
TunerStudio tachometer shows on startup from 130 to 230, I think it means is that the EDIS
maybe I was wrong when put in R12 1K resistor, was written (not remember which forum) that ought to be 4K
Old Nov 2, 2010 | 08:55 AM
chaffe's Avatar
chaffe
Can you see RPMs in megasquirt though? does it run at all?
Old Nov 2, 2010 | 08:56 AM
chaffe's Avatar
chaffe
i would switch off any sort of ego correction completly for the first start up, it just confuses the situation.
Old Nov 2, 2010 | 09:22 AM
red_spider's Avatar
red_spider
so I see RPMs in megasquirt
Old Nov 2, 2010 | 09:25 AM
red_spider's Avatar
red_spider
Old Nov 2, 2010 | 09:27 AM
red_spider's Avatar
red_spider
Oki
Old Nov 2, 2010 | 09:51 AM
chaffe's Avatar
chaffe
LOL, Does it run at all? or just pop and bang, what are the exact symptoms mate
Old Nov 2, 2010 | 10:02 AM
red_spider's Avatar
red_spider
best result obtained with the data settings is quiet constant explosions of degrees 13.5 and 14% Throttle Position, and other times nothing at all sometimes only single loud explosion
Old Nov 2, 2010 | 10:35 AM
chaffe's Avatar
chaffe
sounds like an ignition timing problem. is the TPS calibrated also? try disconnecting the pip and saw wires to the edis module.
Old Nov 2, 2010 | 11:16 AM
red_spider's Avatar
red_spider
yes
ok well I'll try
Old Nov 2, 2010 | 11:20 AM
chaffe's Avatar
chaffe
Just seems a bit funky, have you tried upping the priming pulse to give it a good bit of fuel to start on?
Old Nov 2, 2010 | 10:22 PM
red_spider's Avatar
red_spider
I tried to raise the value Cranking Pulswidth but that does not work
if you're talking about it?
Old Nov 3, 2010 | 07:44 AM
chaffe's Avatar
chaffe
silly question, but the fuel pump is def running when you crank? it should start!
Old Nov 3, 2010 | 08:34 AM
red_spider's Avatar
red_spider
yes
I've checked everything is gasoline, is spark, is the pressure of petrol
maybe someone has settings for MS2, for a standard engine?
I first worked with MS and so I have no experience in setting up
Old Nov 3, 2010 | 08:35 AM
chaffe's Avatar
chaffe
without looking at it, it is hard to say
Old Jun 21, 2011 | 08:29 AM
red_spider's Avatar
red_spider
hi all, I am here again One problem resolved edis was broken,
but I will still rebuilt MS, buying BIP373
and ...
new 440cc injectors
cams newman 409T
and new problems running this time configuration problem.
I just do not have much experience in the settings so please help
changes in the settings ....
new RequiredFuel 6.1 ms
question ford coil pack
whether these settings enough?
yesterday for the first time managed to get warmed on idling engines
but PWM idle Duty Cycle 60-59
this is normal?
my table
I used TunerStudioMS and VE Analyze Live
Table of ARF
I got a table VE
but engine performance is not stable
My settings http://www.ford-orion-rs.com/images/....07.37.msq.zip
and
log file http://www.ford-orion-rs.com/images/....05.51.msl.zip
EoinXR3
Sep 7, 2015 05:44 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
marky_g
Aug 15, 2015 10:43 AM
Roosie
Aug 13, 2015 07:40 PM
Zoggon
Aug 10, 2015 10:39 AM
