t38 fit 2.1zvh
24-08-2010, 07:55 PM
t38 fit 2.1zvh
hi can anyone tell me if a t38 would work well on a 2.1 zvh just curious engine Spec is phase 5 newman cam, stage 3 head, stainless valves, wossner pistons, cosworth management, green injectors
24-08-2010, 08:05 PM
ill be corrected if im wrong... but pretty sure a t38 wouldn't work well on that at all. as its still only an 8v head so would be extremely laggy and probly wouldn't make boost till around 5,500-6,000 rpm at a guess. so imo not the correct choice.
it will work but your definition of "well" to someone elses might vary as will what you plan to do with the car
24-08-2010, 08:08 PM
it would drive like shit if it was fitted, t34/48 housing is the one you need
24-08-2010, 08:11 PM
Thanks for the answers just seen it on ebay
24-08-2010, 08:12 PM
Thanks for the answers just seen one on ebay
25-08-2010, 09:33 AM
powered by K26
i run a KKK26 sort of the size of a t38 and it works a treat. it makes boost around 3-3.5.
25-08-2010, 05:42 PM
hopefully it should work ok, will tell you soon as my bro has fitted one to his.
Just got to finish off the inlet and wiring for the management then hopefully flying
25-08-2010, 09:42 PM
Has anyone else had a t38 on a zvh?
26-08-2010, 12:04 PM
powered by K26
weve got a couple of zvhs of GT30s
Kyle Langford
27
05-08-2019 07:54 PM
ekjim
27-08-2015 05:20 PM
Dr. Ickxs
15-08-2015 11:34 AM
marky_g
15-08-2015 10:43 AM
track.focus'd
12-08-2015 05:53 PM
