DIY head build and porting pictures inside **UPDATE** finally started
Old Nov 21, 2010 | 06:31 PM
  #81
Karlos G's Avatar
Karlos G
Balls Deep!
Looks good Rob nice work, shame you couldnt do a before and after flow test.
Old Nov 21, 2010 | 06:40 PM
  #82
Rob_DOHC's Avatar
Rob_DOHC
Cheers mate, yea i know would have loved to have it flow tested but just couldn't find any one close plus im running out of time a bit. From all the research i did peak flow figures aren't really the be all and end all of a decent head. Haven't really changed anything too drastic inlet side, just slightly larger and smoother lol
My initial engine spec wont have changed very much. Same cam, turbo etc so i will do a dyno run and compare, if i make the same or more power at the same boost with the lower CR the head has been an improvement
Rob,
Old Nov 21, 2010 | 06:47 PM
  #83
Karlos G's Avatar
Karlos G
Balls Deep!
You must be itching to get it up and running now, I hate waiting on a build or a new mod!
I fitted my new Tacho and Speedo the other day and now REALLY cant wait for my Fuel and Water Temp gauges from Santa lol
Old Nov 21, 2010 | 06:52 PM
  #84
Rob_DOHC's Avatar
Rob_DOHC
Lol, cant you ask santa to drop them off early lol and im fairly desperate to get it up and running! haven't driven it for a year now
Rob,
Old Nov 21, 2010 | 06:57 PM
  #85
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah if only!! I get so impatient if I had the spare cash I'd buy them myself and then ask for something else for chirstmas lol
Mines never been off the road for a year, I think 6 months max and that was a fucking nightmare! Driving around in a 1.1 AX Forte!
Old Nov 21, 2010 | 09:13 PM
  #86
Canada1's Avatar
Canada1
Good job Rob,
Smoothing out the sharp edges certainly will make a good bit of difference on both
inlet and exhaus side.
I agree peak flow figures are not all that usefull. However, the cvh head is difficult to get over the 165 cfm(28" depression and .450" lift) mark - even with large ground out ports. There are certain areas just below the valve that need reshaping.
One cannot discover this without the aid of a flowbench - or many years of blind trial and error building race engines. Instead of a flowbench to test the results of port reshaping one had to rely on dyno power or racetrack performance. For me I do not have years of building championship CVH engines to know where (other than initial common sense) to remove material (and where not to) so I choose the flowbench as a tool to do this.
Also careful examination of cross sectional flow velocities in the port and also exiting around the valve.
Perry
Old Nov 21, 2010 | 09:46 PM
  #87
Rob_DOHC's Avatar
Rob_DOHC
Cheers mate,
I was pretty careful around the back of the valve, and i'm hoping the 3 angle seats with cut back inlet valves should help at low lift. My aim was to use the standard valves, and keep the port area down. Im hoping to have a good torquey lowish lag motor, not aiming for a peaky 300brake, more a nice drivable 250 brake with similar torque figures.
What sort of features did you change around the back of the valve?
Thanks again,
Rob,
Old Nov 22, 2010 | 03:38 PM
  #88
Canada1's Avatar
Canada1
Hello Rob,
Your head pics look good so far
I left my exhaust port exit size much smaller to keep up exhaust velocity.
We tested a port making it larger (almost the same size as ERST turbo manifold)
and did not see any flow increase. This means a definite velocity decrease.
Removing the intake valve guide in the inlet port is also a good thing. We saw a 10 to 12 cfm gain by removing the protruding guide. The air velocity near that valve guide is
extremely high. A 10 cfm increase in flow (if velocities are still in a good range) will yield
20 HP at 15 psi boost.
One note of caution - the inlet manifold.
The inlet manifold is a source of major airflow restriction as well.
Porting the cylinder head by itself, and not looking at the intake manifold
is a huge mistake.
We have ported a cvh head with standard 42mm valve to reach 193 cfm @28" and 0.450" valve lift. This was with a 36mm diameter inlet port (near factory size).
However, when we added the intake manifold nearly all of our 40+ cfm gain was gone.
After reshaping the inlet manifold we are at 175 cfm - still alot to gain.
I can certainly see a large gain made from a propper tested intake manifold.
Again, we would not have discovered how bad a factory intake was without the aid of a flowbench. Anyone who says flowbenches are useless - is fos.
Increasing the efficiency of the entire inlet path is free HP. Increased power at lower boost levels.
Cheers,
Perry
Old Nov 22, 2010 | 04:12 PM
  #89
Karlos G's Avatar
Karlos G
Balls Deep!
Hmmm... might be worth investing a few pennies in a custom inlet manifold to complement my NMS head then
I always thought EFI inlets were reported to flow pretty well?
Old Nov 22, 2010 | 04:25 PM
  #90
Canada1's Avatar
Canada1
Hello Karlos,
Unless one actually tests the flow of an intake manifold on a cylinder head you don't really know.
The harder (more expensive) way is switching inlet manifolds and testing on a rolling road.
A factory unmodified inlet will not support the airflow requirements of a modified head.
The factory manifolds may be modified to produce good results.
However, nearly all of the big HP guys have custom inlet manifolds - or at least modified factory inlets.
The inlet is far more important that a tubular exhaust manifold - up to 300 HP.
Just my opinion
Old Nov 22, 2010 | 04:28 PM
  #91
Karlos G's Avatar
Karlos G
Balls Deep!
I want one like these now! lol
Old Nov 22, 2010 | 04:42 PM
  #92
Rob_DOHC's Avatar
Rob_DOHC
Cheers Perry, shame about the exhaust port good thing to know for next time the inlets them selves are close to factory size, inlet manifold is next, made up a template to match the inlet to.
Have you flow tested a efi and mfi manifold back to back? im running my car in with the efi manifold but considering cutting open my mfi manifold to properly sort out the internal casting and having it re-tig welded.
Karlos - always loved the look of those manifolds when their done properly think one would really suit your car mate, im going to stick with the mfi manifold as i really want a stock looking bay.
Rob,
Old Nov 22, 2010 | 04:52 PM
  #93
crazycage's Avatar
crazycage
karlos ,have you seen the inlet on richies escort?
Old Nov 22, 2010 | 05:06 PM
  #94
Karlos G's Avatar
Karlos G
Balls Deep!
No Gary I havent mate, pics? Is it one you made?
Old Nov 22, 2010 | 05:47 PM
  #95
crazycage's Avatar
crazycage
yes i made it mate, but the only pic i can find is of the inside of it lol.
Old Nov 22, 2010 | 08:32 PM
  #96
Karlos G's Avatar
Karlos G
Balls Deep!
Get Ritchie to post a pic up mate, and PM me a price
Old Nov 23, 2010 | 08:51 AM
  #97
s1cab's Avatar
s1cab
+2
Old Nov 23, 2010 | 09:00 AM
  #98
Karlos G's Avatar
Karlos G
Balls Deep!
I found these pics Gary but they look to be a different one?
Old Nov 23, 2010 | 01:56 PM
  #99
Canada1's Avatar
Canada1
Hello Karlos and all,
Custom intakes have the ability to flow better - usually just because the runner length is shorter and there is lower losses with a shorter port.
Once again beware - a homeade customized inlet manifold that has not been tested for equal flow in all 4 ports is taking a risk.
That is where flowbench development is critical.
You will find many builders saying flow benches are useless - they are full of rubbish.
How can you look at an inlet manifold and know that the flow distribution is equal?
The are some computational fluid dynamics software used for inlet development - these do work well , but the finished result is verified by - - - guess what? a flow bench.
Equal flow distribution means equal power for each cylinder and no lean cylinders to burn pistons. This is part of a good tune.
Flow bench testing here is not very expensive. Much less than the cost of inlet manifolds and head porting. One can have an inlet manifold and head tested for
$200.00 (all 4 ports) (less than 100 Ł)
All of this extra effort will lead to a relaible, much more powerful(at lower boost) engine.
Hope this helps.
Old Nov 23, 2010 | 02:53 PM
  #100
essexRSTSouthend's Avatar
essexRSTSouthend
Looking good rob.some handy advice canada.i had my head done to stage 3 spec.the exhaust side ports were only made slightly bigger compared to other stage3 heads id seen.they used flow bench.bigger is not always better then.anyone know a place who could port my inlet mfi...
Old Nov 23, 2010 | 03:33 PM
  #101
muz's Avatar
muz
Wye Valley Hardcore
I would be interested to see how well my inlet flows compared to an EFi item actually.
Old Nov 23, 2010 | 05:24 PM
  #102
crazycage's Avatar
crazycage
that is one i made karlos but its a early one ,no trumpets and the plenum is also totally differant. ill get a pic at the weekend .
Old Dec 5, 2010 | 06:20 PM
  #103
crazycage's Avatar
crazycage
got a pic of his engine bay today.
Old Dec 5, 2010 | 06:47 PM
  #104
project rs's Avatar
project rs
ooh and i thought you just wanted to mock someones down pipe up on it and instead you were taking sneaky pictures p.s those mtx mounts you do i think i might aswell get my name down now as i think the extra from the gas will see this box of
Old Dec 5, 2010 | 07:27 PM
  #105
s1cab's Avatar
s1cab
could be mine?
Old Dec 5, 2010 | 07:46 PM
  #106
crazycage's Avatar
crazycage
Originally Posted by s1cab
could be mine?
it was mate , its all tacked up just need to tig weld the elbow in the morning .
Old Dec 5, 2010 | 08:46 PM
  #107
s1cab's Avatar
s1cab
looks
Old Apr 1, 2017 | 07:16 AM
  #108
tbali123's Avatar
tbali123
Hello all,
I've found this topic very interesting and extremely useful! Thanks for all the information, based on these I've made myself a ported head for my mfi XR3i.
Using a Dremel tool, I made the inlets match with the head perfectly. At first, I was afraid that this will reduce swirling and by this, fuel atomisation. But then I've noticed that the port shape should be enough for good atomisation and mixture, because it generates a good swirl.
DIY head build and porting pictures inside **UPDATE** finally started-20170223_164519.jpg
DIY head build and porting pictures inside **UPDATE** finally started-20170223_164536.jpg
DIY head build and porting pictures inside **UPDATE** finally started-20170226_143101.jpg
DIY head build and porting pictures inside **UPDATE** finally started-20170226_143107.jpg
I did some machining behind the throttle body, too.
DIY head build and porting pictures inside **UPDATE** finally started-20170223_164618.jpg
I'll make more pictures soon...
Anyway, here is my Escort:
DIY head build and porting pictures inside **UPDATE** finally started-20170313_175447_richtone-hdr-.jpg
DIY head build and porting pictures inside **UPDATE** finally started-20170313_175505_richtone-hdr-.jpg
Rob, have you finished the ported head? How is the RST going? I see this thread ended in 2010 without built in results,I hope everything is ok.
Cheers,
Balazs
steerfromdarear
28
Jan 29, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
