still smoking!!!!!
still smoking!!!!!
hi there i need some help on trying to get my car from stop smoking. ive changed the valve stem oil seals and head gasket but it still ploomes with smoke on start up but clears wen its warm. any ideas what this could be?
cheers.
cheers.
tools make sure you have a good pen magnet to get the collets out to remove the valve springs out..
just turn the engine over untill the one you are changing is slack and push down hard with a big ring spaner on the ring end or get a valve spring press and use the magnet to remove the collets take of the spring and fit new stem seals... then just put it back how it was. then there is no need to remove head.....
hope this helps
the only thing i will say is the turbo can leak from the turbine seal thought
blowby and heavy breathing engine
the turbine seal is a small piston ring and will be the first seal to blow when
the is a lot of crank pressure also bigger turbo exhaust housing will help
to leak as there is less back pressure in the exhaust
just something to think about
i had the same on mine and i found that it was running rich my m8 put it on c02 meter and sorted it out then no oil burn on start up.....?????god no's what it did?
Steve Escos
01-10-2015 06:57 AM
