megasquirt help
hi just a simple question when i turn the ecu on the first light breifly lights up then goes out, is this ment to happen or what does it mean? and im also struggling to to get the ecu to connect to the laptop. any help would be great thanks juff
ok as far as i know the ecu powers up with 1of the 3 lights coming on then going off and im using the cable that was supplied with it everything else is unkown to me untill i start getting to know the softwear this is the first time i have used it, please explain simply
Bodger of Blackburn
if MS1, then 9600
if MS2 then 115200
are you using a usb to serial cable?
if so make sure it has the right drivers and you check your com port in control panel-sytem-device manager select ports and check the settings.
set the buffering to lowest setting to keep reliable too.
if MS2 then 115200
Balls Deep!
Where did you buy your ECU from? All the info you need to set it up with your lappy should be on the cd you got with it in a step by step guide.
If not then here you go............
MS Setting should look like this, but your Port should match whatever COM Port your computer shows in the screen shot below in this case COM 6.
![](http://i413.photobucket.com/albums/pp217/Th3blueroom/MSSettings.jpg)
To get to this screen, right click My Computer, Properties, Device Manager..
![](http://i413.photobucket.com/albums/pp217/Th3blueroom/Port.jpg)
In the above screen shot yours will not say USB Serial Port because that is my USB to Serial adapter and you are not using one, so it will just say COM # or Serial Port or somthing like that, should be pretty easy to spot as it wil probably be the only Serial device plugged into your PC!
You may also need to double click that and change the following setting to the same baud rate as MS which is 115200..
![](http://i413.photobucket.com/albums/pp217/Th3blueroom/PortSettings.jpg)
i have now got it to work through ms1 extra software baud 9600 rate. does this mean it is a ms1 as i bought it as a ms2? what is the easiest way to tell, please help as i will ring up the supplier tomorrow as i have had nothing but problems as i thought it was the ms2
i will let you know if i dont get any joy tommorow. i dont want to say names unless they are not willing to help. Thankyou for the help guys. much appreatiated.
Is there any way of telling or visuall inside that would confirm it as ms1?
1.8 esc
11
22-06-2006 12:48 PM
