mfi metering head help
ju st replaced engine in rs turbo that had blown up.I brought it not running and
abandon it in a lock up for just over a year. i have the new engine all fitted but
it fires some times but won,t stay running.I have got good fuel pressure to the
metering head and the cold start injector but nothing to 4 injectors.It will run if i
give a sniff of easy start so diffanately fuel. any one have any ideas?
thanks jim
thanks jim
Sounds silly but does the metering head flap move easily? if it has been standing for a long time this may have seized/stiffened up etc. The flap position correlates to how much fuel is injected.
Take an injector out next and look at what it does when the engine is cranked (unplug the cold start injector to avoid totally fludding whilst you are playing about), and when you push on the flap.
Let us know what happens
Rob,
Rob,
Need MOT
I had similar problem, it would fire up on cold start injector but wouldn't run,
No fuel from the 4 injectors, but there was lots of pressure and fuel would spew from the head if the bango bolts were slackened,
Turned out the Pump was drawing air caused by low fuel level, - make sure u got at least 2 jerry cans in the tank -
sometimes it's the simple things,
good luck
chris
good luck
chris
![Talking](https://passionford.com/forum/images/icons/icon10.gif)
Thanks for that chris.As i had plenty of pressure but nothing out
of the banjos didn't think it would be that.But as its a van unknown to me
i put 25ltrs of fuel and it runs. cheers jim
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
