Anyone fitted Xenon HID kit on their rs turbo?
#43
powered by K26
as noticed. the front RS TURBO LIGHT units factory 80spec has a inside light protector and rules out the above. so yes they are legal.
I've had mine checked my VOSA. the law... above the police. as mine last went in for an inspection and the HIDs flagged up was told to change the camber of the light unit down a little. and then was told they dont need any of the above because the early 80spec standard ford light fittmens have the snow white cristal lense that dims them from glear. its the main inside front light protector.
#46
and do you think the s1 lights would be ok to fit xenon?
#47
Lee
#48
Fast Ford snapper
I've actually got a new set sitting somewhere!
Used to use 130W H4s in my first Mk3 Escort. They worked great and didn't flare out either. Ran heavier cabling and used extra relays for them though.... Oh yeah and they're illegal, but no cop's ever going to know
#49
Fitted my HID kit today and there fucking quality! Avoided the Ł20 sets off ebay that are obviously going to be shit, paid abit more and got some with a 2year warranty. They dont dazzle on-coming traffic or flicker. I set the beam up nicely at my mates garage an they look proper good. Got the 4300k set so they are white, they look wank when there blue. Think the company is called ultra and i would recommend them to anyone
#50
Bought 6000k as they are not as blue and the beam can be adjusted to a non blinding level.
#52
powered by K26
powered by K26
fitted mine aswell over the holidays and i really can't believe how much the old lights were draining the power from the car! the xenons don't do this at all! my clock lights are now brighter and i can now see the blue high beam light cleary. the light is unreal and just makes the old system look out of date. would agree buy cheap and you buy crap.
this might be a silly question but, can you still flash your lights and get main beam?
#60
Takes approx 30mins to fit and you retain the same h4 mounts no mods required, the only thing i did mod were the rubber caps that go on the back of the headlamps to stop water getting in but that's a 2 min job to make the hole bigger. the rest is just adding a + wire to battery and 2 ground straps to the car body or battery and then plug the loom into one of the bulb sockets to get the switches working.
YOU will need to get a beam aligner to get the beam correct as there is no way to set that yourself.
marky_g
15-08-2015 10:43 AM
track.focus'd
12-08-2015 05:53 PM
