Fuel tank
Fuel tank
I have a H plate escort rs turbo (with fuel computer) and needing to replace the fuel tank. My local motor factor lists two different ones- non efi and efi tanks. The difference is the sender hole size. Can anyone tell me which one i need. I was under the impression there was no efi rs turbos, is the efi one for the late xr3i only?
When they ask you if its EFi its because there was actually an Escort mk 4 model called EFI,
This would NOT be the one. If I remember rightly yours would have an extra 'pipe' sticking out for the fuel return.
no, there are 2 different tanks for the rs turbo
the larger sized sender unit hole is on earlier models, the smaller sized sender unit holes is for the later 90 spec models i do believe
so, judging by it being a H plate with fuel computer, id say later spec small sender unit
..BS Motorsport..
RSandy- Yes that confirms what i was led to believe thanks.
StephenC- Thanks for link i done a search but nothing came up again that sounds right. Im going to risk the smaller sender one.
Deffo smaller sender hole for a genuine 90 spec car! I have both cars (pre and post 90 spec)and have recently had the tank out of both of them!
