actuator preload = approx boost
![Post](https://passionford.com/forum/images/icons/icon1.gif)
I've just fitted a new -31 actuator to my t3. I have preloaded to approximately half a hole. WITHOUT any bleed, what level of boost should I expect to see at this load level?
Also, what should I expect to see at a complete hole of load or is this a bad idea and would I be better off bleeding to make the required boost level?
Thanks
Thanks
You would see around 0.6-0.7 bar of boost, and typically it's not a very good idea to much increse the preload. If you need to, you have the wrong actuator to start with.
It's a better idea to use a proper boost control. I like to use Megasquirt for that.
I'm sure I have the correct actuator. So what you're saying is if half a hole gives me 0.6bar and thats not enough then I have the wrong actuator?!
I'm thinking half a hole = approx 0.6bar. I'm looking for 1bar max (ofac efi) therefore bleed a further 0.4bar and bingo am I wrong??
JK12
33
26-04-2021 12:09 PM
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
