Guys running 300+ bhp how are you putting down the power?
Old 10-07-2009, 09:56 PM
morph
morph's Avatar
Default Guys running 300+ bhp how are you putting down the power?
Wanted to know what mods you lot run to stop the rs turbo from spinning up?
is there any good tips?
i have adjustable tca's
and a bigger turbo
planning to get a atb diff.
cheers
Old 10-07-2009, 10:02 PM
bigryrs
RSHoleinator
bigryrs's Avatar
and a bigger turbo
cheers
I have all the above but its all in bits so il let you know next year lol
Old 10-07-2009, 10:17 PM
DanS
DanS's Avatar
Tyres will make a massive difference
Get some Toyo R888s on it, made a huge difference to mine!
Old 10-07-2009, 10:22 PM
AzE_B
AzE_B's Avatar
on my starlet i had 888 a cusco LSD and aint lift kit there the things i found helped the most
Old 11-07-2009, 01:35 AM
Micky
Micky's Avatar
Could'nt tell you,I only have 250 BHP!!!! Will only be a handfull of proper 300+ BHP RST's on here.Regards,Micky
Old 11-07-2009, 05:10 AM
Pat
Pat's Avatar
Default 300
Well i wont claim to have 300 but im certainly not far off..
I have a quaife diff which does help.. BUT i still have major problems with traction.. as someone said tyres will be next for me..
Old 11-07-2009, 05:38 AM
pacwest
Puller of the Wrench
pacwest's Avatar
With my right foot!
Yoko race rubber, Cossie diff, Zero'd back end.
Old 11-07-2009, 06:11 AM
jonny s2
jonny s2's Avatar
with the rest already mentioned,id say suspension geometry set up a must
Old 11-07-2009, 07:41 AM
crazycage
crazycage's Avatar
215/50/15 R888s
coilovers (set up right)
polly bushed
adjustable bottom arms
equal lenght drive shafts
focus rs box with diff
and it puts well over 300hp down no problem
Old 11-07-2009, 07:52 AM
sas
should be good!
sas's Avatar
205 50 15 R888 tyres
Koni shocks
polly bushes
ATB diff
A tested "toe out" setting
Old 11-07-2009, 09:26 AM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Sticky tyres are a good way, but remember that the more grip you give it, the more likely you are to bust gearboxes.
I'm running 305bhp at the moment, it's my low-boost setting and it's amazing how sedate it feels. It's really laying the power down well. Not sure how it will be when I crank the boost up.
Old 11-07-2009, 10:01 AM
Antti O
Antti O's Avatar
I dont have 300, not even 230 maybe. My rst ran 14.4 / 164kmh quarter without wheelspin. I believe i can add 50bhp more and still no wheelspin problems.
I have simple packet:
Koni yellows
Powerflex
H&R Springs
Toyo T1R standard 15"
std lsd
Old 11-07-2009, 11:46 AM
morph
morph's Avatar
Ok i can't go with 888 as they dont do them in 195 x 40 or 45 and i am running escos wheels.
Old 11-07-2009, 12:12 PM
gus
gus's Avatar
mine use to run
gaz t/a suspension
eibach springs
poly bushed
adj tca's
think i had yoko a520's (not the best but ok in dry)
then i had all geometry set up
wasnt too bad really, lit the wheels if wanted to but once you got use to it was fine
Old 11-07-2009, 01:03 PM
s1cab
s1cab's Avatar
305bhp @ low boost !!
Old 11-07-2009, 01:13 PM
stevenebm
post whore
stevenebm's Avatar
got full mef set up on rs1600i crossmember.adjutable tca's.coilovers and some toyo's.will be gettin it fully set up at sitech.only problem i have is ive only got about 250bhphopin for a decent mix of power and grip tho.
Old 11-07-2009, 02:20 PM
Christian and Beccy
#1 in Spelling Club
LOL. My low boost is 1.5 bar to be fair.
Old 11-07-2009, 03:17 PM
s1cab
s1cab's Avatar
and mines 28psi to make 276bhp ! sounds like a perfect setup
Old 11-07-2009, 05:56 PM
morph
morph's Avatar
and that is really sedate? are you running a laggy turbo?
1.5 bar that works out at around 25psi?
Old 11-07-2009, 05:57 PM
morph
morph's Avatar
Originally Posted by gus
mine use to run
gaz t/a suspension
eibach springs
poly bushed
adj tca's
and what power would that have been?
Old 11-07-2009, 05:58 PM
morph
morph's Avatar
Koni shocks
polly bushes
ATB diff
what toe out are you talking?
morph
morph's Avatar
Originally Posted by crazycage
215/50/15 R888s
polly bushed
how did you run the equal lenght driveshafts? and what diff does that make?
Old 11-07-2009, 06:28 PM
crazycage
crazycage's Avatar
mines a zetec turbo mate, and there ment to help with torque steer
Old 11-07-2009, 07:33 PM
stevenebm
post whore
stevenebm's Avatar
well say 14.5 to a bar so id say 22psi
Old 11-07-2009, 07:50 PM
gus
gus's Avatar
319bhp cant remember what the torques was
Old 11-07-2009, 10:09 PM
Christian and Beccy
#1 in Spelling Club
I'm running a fairly big turbo. Response isn't top priority.
Feels fucking ace on the road though. I did have a nasty torque-steery scary overtake moment on the way home tonight though. It's like torque-steer but up another notch. :cry;
Old 12-07-2009, 12:06 AM
morph
morph's Avatar
laggy turbo sort of stops the whole wheel spining problem.
Old 12-07-2009, 01:31 PM
JamboRS
focus rs 1672
JamboRS's Avatar
whys that???
Old 12-07-2009, 02:32 PM
s1cab
s1cab's Avatar
whats the minimum size turbo to break the 300bhp mark? can you do it on a stage 3 t3 or will it have to be a t34??
Old 12-07-2009, 02:40 PM
gus
gus's Avatar
mine and tom scarlets old one both made 300+ on t3's
but
it was pushing it
mine sort blew itself to bits, then i was running wild als without a proper shaft
Old 12-07-2009, 02:44 PM
Christian and Beccy
#1 in Spelling Club
I would say of all the things that stop it wheel-spinning, the laggy turbo isn't one of them. It'll just light the wheels up higher up the RPM's.
Old 12-07-2009, 05:15 PM
morph
morph's Avatar
Originally Posted by JamboRST
whys that???
Because by the time you get the car to boost the car is rolling so there is less weight to pull as the car is in motion. its a bit like this 0-60 thing, nearly all fwd cars will be much slower than 4wd and rwd and manufacters allways use this as a performance figure for all cars.
when in fact the true figure to understand a cars ability is a rolling car when says it already doing 30mph and then you measure how quick the car will reach 100 or 120,130mph.
i had a 2wd cossie turbo on my rs turbo and it would not come in on full boost any earlier than 4k rpm, but compared to my previous t3 it would not spin the wheels.
Old 12-07-2009, 05:18 PM
morph
morph's Avatar
didnt find this with mine, found that by the time the turbo was boosting fully the car was rolling enough to not break traction, but i didn't like the nature of this as around town it was too lame lower down and a very narrow power band!
Old 12-07-2009, 05:41 PM
JamboRS
focus rs 1672
JamboRS's Avatar
thanks for educating me
Old 12-07-2009, 05:48 PM
crazycage
crazycage's Avatar
i just use my right foot
Old 12-07-2009, 08:20 PM
stuart collins
stuart collins's Avatar
dont no last time i drove mine it was spinning in 5th lol
loads of changes now tho so with abit of luck it will put it down
Old 12-07-2009, 08:51 PM
stuartrsturbo
stuartrsturbo's Avatar
Jamie and scot were trying to get me to run the same rear end set up as yours. Looks alot neater than standard (I know you haven't done it for that reason).
Old 12-07-2009, 09:30 PM
morph
morph's Avatar
Thumbs up
not a problem mate!
Old 12-07-2009, 10:25 PM
rstdave
rstdave's Avatar
I think a lot of the problem is how the boost comes in, whether you're running a small or large turbo to be honest....it's amazing the difference a well mapped car can drive compared to one of the same power but mapped differently. 300bhp+ is always going to be hard work to put down easily in an rs turbo, does depend what you want the car for (track/road/qtr mile etc etc) as to how you want your power delivery. My old engine at 250bhp was nothing like as bad as the majority of people thought it would be with regards wheelspinning, did depend how you drove it as to how it put the power down though. My new engine when i put a bigger turbo on it should be up round 300 so will just have to see what happpens and make alteration and improvements as i see necessary.
Old 13-07-2009, 10:29 AM
JamboRS
focus rs 1672
JamboRS's Avatar
not a problem mate!
cheers so basically to reduce wheelspin u put a turbo to big for ur spec so its a lag monster and u dont see full boost to 4k rpm,am i gettin that right??
Quick Reply: Guys running 300+ bhp how are you putting down the power?
