t34 turbo on 1.6cvh?
Old 21-06-2009, 11:21 AM
jonny s2
jonny s2's Avatar
Default t34 turbo on 1.6cvh?
ok guys,got a t34-48 with 360 bearing,and planning putting it on my freshly built 1.6cvh, wanting to know roughly wot power il be running.ok so heres the spec.ported head newman cam solid lifters 7-8-1 mahl pistons arp rod bolts throughout lightened an balanced bottom end 4paddle clutch,cossie 803 green injectors 3bar map,dta management.cossie t34-48-360bearing-31act, with full 3" straight through exhaust, was wondering if anyone knws the boost i should be running and wot sort of power the turbo can handle
Old 21-06-2009, 11:33 AM
clarke5700
YES I KNOW I CANT SPELL
clarke5700's Avatar
i would say at a rough gess limit the power at 230-240 due to standard rods.
just a wiled gess tho
Old 21-06-2009, 11:42 AM
jonny s2
jonny s2's Avatar
yeah was thinking between 230-250,just to run it in then change the rods, as the pistons are rated to atleast 350hp. was originally going to drop my full zetec turbo in but things are taking timewhich i knw i could get alot more from. but quite like the cvh
Old 21-06-2009, 12:55 PM
DazC
DazC's Avatar
I'd not push it past 250 on standard rods. Change them and you should be able to see over 300.
Old 21-06-2009, 01:08 PM
jonny s2
jonny s2's Avatar
dont intend wringing its neck without the rods, daz do you knw wot boost i should be running with that spec? when its run in i shall change the rods, thanks for the sugestions
Old 21-06-2009, 01:13 PM
Herbo747
Herbo747's Avatar
I would personally run around the 18psi mark should be fine its purely the rods that hold it back.
Old 21-06-2009, 01:49 PM
Rick
Rick's Avatar
if the pistons are 7.8:1 they are std machined items, so around 16-18psi is your limit before you'll do a land.
Rick.
Old 21-06-2009, 03:37 PM
rstdave
rstdave's Avatar
Sorry to hijack....bin thinkin about another turbo for my new spec engine and thought about a t34 0.48, wondering how laggy they are on a 1.6 though, anyone care to enlighten??!! 300bhp at what boost??
Old 21-06-2009, 03:51 PM
gus
gus's Avatar
i would look at a roller bearing core really
mine if not driving in high revs was real laggy, didnt like it as much as when running a t3
hopefully this new thing i have should do the biz
Old 21-06-2009, 03:52 PM
clarke5700
clarke5700's Avatar
why are you lot thinking about what psi of boost to run?? you need to be aiming at a bhp figure one engine might make 180bhp @ 18psi yet another 230 @ 18psi it all depends on your engines volumetrick efficanty IMO
Old 21-06-2009, 04:01 PM
rstdave
rstdave's Avatar
Yeah roller bearing is the way i'm going, obviously it's all a bit of a gamble as i don't know what's proven to work for bigger bhp and no-one exactly shares any tips lol. Exactly what you're saying is what i don't want, my t3 running 250bhp is pretty snappy and i don't want a laggy pig as i use it on track mainly.
Old 21-06-2009, 05:45 PM
Rick
Rick's Avatar
T34 isn't laggy on a 1.6 in my experience.
Rick.
Old 21-06-2009, 06:08 PM
gus
gus's Avatar
when compared to a t3?
Old 21-06-2009, 06:20 PM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Rick.
Yeah, I see your point. My machined Mahle's didn't like 16-18psi. They preferred 30psi, 300bhp and 160+mph.
Old 21-06-2009, 06:26 PM
jonny s2
jonny s2's Avatar
hi guys, i understand that the t34 is more laggy than a t3 originally i planned to strap it to my zetec turbo, just wondering wot it would do on my cvh-mahle pistons can handle 350hp and we all know how crap the rods are,i plan to change the rods once ive mapped it,we are mapping the car our selves hopefully we can dial some of the lag out as its standalone management, once again i thank everyone for your input, john
Old 21-06-2009, 08:19 PM
Rick
Rick's Avatar
Borrowed time thou C.
Old 21-06-2009, 08:22 PM
morph
morph's Avatar
have you thought about running anti-lag to get rid of the lag?
its does the job on a t34 turbo!
Old 21-06-2009, 08:25 PM
Tim
Tim's Avatar
agreed never had a problem never melted or broke a ring land i would say they are by far the best piston i used ,until this last engine.
Old 21-06-2009, 08:28 PM
jonny s2
jonny s2's Avatar
yes we maybe fitting anti lag an also a turbo restrictor to reduce this once its been mapped, obviously after the steel rods have been fitted,
Old 21-06-2009, 08:31 PM
Tim
Tim's Avatar
to answer your question about the t34 only change up when you have maxed out the compressor otherwise its pretty pointless tbh.
Old 21-06-2009, 09:15 PM
Christian and Beccy
#1 in Spelling Club
Rick, I ran those pistons for years! They were removed, I think, in 2005 (see my project thread). They were in very good condition when they came out and certainly weren't changed because they failed!
Good pistons IMO, under-rated.
Old 21-06-2009, 09:16 PM
Christian and Beccy
#1 in Spelling Club
Don't get too carried away with ALS though, it's not going to make a laggy turbo OK.
Old 21-06-2009, 09:17 PM
jonny s2
jonny s2's Avatar
thankyou christian for covering that
Old 21-06-2009, 11:53 PM
Micky
Micky's Avatar
I run a t34-48,don't notice any real lag,but mine is only used on track,so rev's are always used.But if you let it fall out of the medium revs,then lag becomes a problem.I'm guessing a 3-5 second wait for lag to dissappear.But again,why would you drive the car badly to let the revs drop in the 1st place?????Regards,Micky
Old 26-06-2009, 10:09 PM
COLEYST200
COLEYST200's Avatar
so lets get this right you are going to put the motor togever put it in the car run it in th en take it out pull iy all to bits put new rods in then put it back in the car ....that is just mad to do the job twice
Old 27-06-2009, 08:07 AM
Rick
Rick's Avatar
C, i've seen a number of mahle ring lands crack. My own did about 30k before faiing. No damage to the anything else, and an easy fix but i can't put my faith in them for an engine built to last.
Rick.
Old 27-06-2009, 11:32 AM
jonny s2
jonny s2's Avatar
mad?not really this would just to get some sort of map,then if we liked it how it ran then build a higher spec engine ie with steel rods,originally the zetec turbo was planned and would handle that turbo perfectly, just wondering wot it would do on the cvh,ie wot boost and power it would run, people who have had expierience with this cheers
Old 28-06-2009, 11:32 AM
morph
morph's Avatar
If your going to run big bhp, then there are other reasons like the lag will make the power band much higher which will help with traction issues as the car will be rolling more, whereas a smaller turbo coming in would probably overwhelm the front wheels as the power band starts alot lower down.
i found this with my setup when i had a t3 stage 2 and then went to a t34.
the t3 would make the car spin up very easily but the t34 didn't!
Old 28-06-2009, 04:11 PM
jonny s2
jonny s2's Avatar
Originally Posted by morph
if your going to run big bhp, then there are other reasons like the lag will make the power band much higher which will help with traction issues as the car will be rolling more, whereas a smaller turbo coming in would probably overwhelm the front wheels as the power band starts alot lower down.
I found this with my setup when i had a t3 stage 2 and then went to a t34.
The t3 would make the car spin up very easily but the t34 didn't!
thankyou very much morph,did you find the t34 a better drive as in power delivery?
Old 28-06-2009, 04:47 PM
RSTurboSI
RSTurboSI's Avatar
my question is, why you running standard legs? why didnt you go steal rods? lol
Old 28-06-2009, 05:01 PM
jonny s2
jonny s2's Avatar
TBH MATE THE ENGINE GOT BUILT FOR ANOTHER PROJECT WHICH I AM NO LONGER CARRYING ON,WE ONLY WANTED AROUND 240HP FROM THIS IN THE PREVIOUS PROJECT, I AM AWAITING FOR BITS TO ARRIVE FOR MY ZETEC TURBO,SO REALLY JUST WANT TO HAVE A PLAY AND LEARN MORE ABOUT MAPPING AN DEVELOPING, LATTER ON THIS CVH WILL BE IN ANOTHER SHELL AND RUN AT AROUND 240 ON A STAGE 3 T3,SORRY IF THIS SOUNDS A LIL SILLY
Old 28-06-2009, 08:28 PM
mart rs
mart rs's Avatar
use the t3 then and have less lag lol
then you only need mapping once dont you
Rsmat
63
25-09-2015 12:11 PM
28
08-09-2015 07:10 PM
RSBryden
06-09-2015 08:39 PM
cozzzzy power
04-09-2015 08:14 AM
turbowag
03-09-2015 08:07 AM
Quick Reply: t34 turbo on 1.6cvh?
