cts stage 2+
13-10-2008, 01:36 PM
cts stage 2+
how much torque will it take
thanks
13-10-2008, 01:59 PM
if u phone them they'll tell u cts-01582840008.
13-10-2008, 04:57 PM
already phoned he said it should take 260+ ft/lb i'm not so sure. does shot peening make that much difference
13-10-2008, 05:01 PM
Colossal Pervert
So the guy who builds them gave you a figure, and then you came on here to ask?
13-10-2008, 06:15 PM
they will hold more though=) just look around and see what some of the guys running it on
13-10-2008, 08:03 PM
id say mine is around 300 an its still holding out
most of the fastest rst around run them olli and tim nms cars also run them.
13-10-2008, 10:29 PM
i would say that 260lb/ft will be a bit of an understatement tbh! a standard one will take 230 lb/ft if treated correctly with no hard launches!!!
13-10-2008, 10:58 PM
i've already got a stage 2 just wondered how much stronger 2+ was or to go with a quaife straight cut
13-10-2008, 11:25 PM
what do these gearboxes cost new? and what prices do they go for second hand if they are available?
14-10-2008, 08:02 AM
Top Cab !!
Quote:
Originally Posted by
Red_bull
about Ł 800
14-10-2008, 02:02 PM
i have one in my fiesta and its running just over 300 lbs, but mine bloody broke, part of the lay shaft and the pinion is broken, waiting to see wat happens, my gear box is at cts at the min, its going to cost me over Ł800 to fix, my box is the stage 2+.
so really, i dont think it can take 300 lbs with huge abuse but having said that my car used to run 341lbs and it did not break then.
i think its down to the way you drive it if you just plant it and dont take your foot off the gass wen its in gear you should be ok, thats wen mine broke, wen i took my foot off the gass
14-10-2008, 03:52 PM
i broke every tooth off 2nd gear and the input shaft, think i'm going with a quaife straight cut kit
JK12
33
26-04-2021 12:09 PM
gcfcos
59
06-10-2015 05:04 PM
Mc5506
05-10-2015 09:57 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
wheelwizardrefurbs
18-09-2015 02:39 PM
