boost problem
Old 16-07-2008 | 08:01 AM
guyver's Avatar
guyver
Default boost problem
hy
my 1.8 zvh boosts to about 0.9bar and then drops in about 5sec to hold 0.5 bar
is this normal??
its got a new 31-actuator
grtz
Old 16-07-2008 | 11:22 AM
Raj B's Avatar
Raj B
230bhp S2 in the making!!
How are you controlling your boost? bleed valve? etc
if so, it is perfectly normal too see a short spike then drop and hold boost, but that does seem like quite a drop in boost
Old 17-07-2008 | 08:02 AM
guyver's Avatar
guyver
hy
i control the boost with the actuator
i also thouth its a big drop in boost
it runs fine so i don't think its an air leak
could it be the pipe's collapsing?? or insn't the boost high enough for that??
grtz
Old 17-07-2008 | 10:07 AM
Smartdj.'s Avatar
Smartdj.
check every thing for leaks...even pin prick holes
Old 17-07-2008 | 10:13 AM
project rs's Avatar
project rs
the spring in the actuator might be to soft or is worn out
Old 18-07-2008 | 08:16 AM
guyver's Avatar
guyver
hy
its a brand new actuator
what's the best way to check for leak's (putting it onder pressure)
grtz
JK12
33
26-04-2021 12:09 PM
oilman
Trader Parts for Sale.
23-09-2015 07:32 PM
Marino
12-09-2015 11:10 AM
morg65
Escort MK 5 / MK 6
11-09-2015 01:55 PM
markk
09-09-2015 08:11 AM
Quick Reply: boost problem
