Problem with Boosting - possible turbo death?
Hi guys,
I’m new here but have heard great things about this forum.
Right, Basically my car went into Motorsport Developments in Blackpool 2 weeks ago and had a setup etc. Everything was fine except i was told the turbo is on its way out and that’s the reason for the howling.
I went to drive it today, and as i accelerated the car started to jerk as though i was not in a high enough gear and wouldn’t boost basically, but if i drove without putting my foot down and kept below 5psi then the car was fine.
I decided to drive it for about 20minutes without the Turbo and then put my foot down again, i got to 7psi and it started jerking and backfiring and just would boost. Also the howling was a little louder than normal.
Is this the turbo shot at as described by Motorsport? I would appreciate any input to this little problem of mine.
Thanks,
Shep.
Thanks,
Shep.
ok guys i think i may go with a new one if i can afford. Is it hard to fit for a novice? i mean once up on ramps is it a big/hard job removing the old and putting in the new?
More boost Igor!
No such thing as a 'cheap' turbo mate
If you skimp on cost to buy a new one or a untested used one, you'll end up either buying a proper new one or spending money rebuilding the used one.
But there are bargains to be had. Just keep away from the chocolate ones on ebay![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
The hard bit is getting out the siezed nuts and bolts, and if you're unlucky like me the bolts that have no head any more.
Matt Baxter
16-09-2015 08:30 PM
CrOwSoN15
18
22-08-2015 10:24 PM
Escortdriver1
31-07-2015 02:36 PM
