just re built car now when it spools up its got no go I think I've missed something is the the pipe onthe regulator on side of metering head anything to do with it cheers help needed
ps no boost leaks found already checked
no but it I's a regulator that is bolted to the metering head on right hand side at back think its return as if has a pipe to injector unit and other goes under car somewhere but there is a vacuum pipe coming off end not piped to anything I don't no what for if anything
