No Spark Problem S2
Old Jan 21, 2004 | 01:35 PM
Default No Spark Problem S2
S2 ERST with 36000 miles
Exhaust,Air Filter, Collins Chip, piper 285t2 cam,grs evo 3 intercooler & recent clifford 500 with remote start...
The Problem.....
There is no spark, changed the coil, and the whole distributor and all the leads are fine...Does anyone know what this could be? The engine is turning over and the fuel pump is working fine. Help cos i am going MAD!!
cheeRS
Old Jan 21, 2004 | 01:52 PM
Probably a wiring problem - trying running a wire straight from the battery onto the black wire on the ignition coil (leave original wires on there aswell). Also check that there is an ignition feed going to the distributer aswell. Again you can run a feed straight from the battery for this.
These are for checking only and if it starts then you know what the problem is. Dont use this as the proper repair.
If this dont work then it is probably related to the ECU but try the simple stuff first.
CheeRS
Old Jan 21, 2004 | 02:11 PM
There is power going to them...
Ive already checked that...
Do you think it could be the electronic spark control in the ECU?
cheeRS
Old Jan 21, 2004 | 02:42 PM
Theres a relay under the dash that will turn the ECU on when you switch the ignition on - Check that as the alarm guy may have tinkered with this when installing the alarm.
With the car only having done 36K i cant see it being something like the electronic spark control. But more likely something the alarm guy has done.
Make sure the ECU is getting an ignition live.
CheeRS
Old Jan 21, 2004 | 05:37 PM
i reckon it might b something 2 do wit ur alarm if u tryed al that and stil no luck then check alarm
Old Jan 22, 2004 | 05:41 PM
still no luck with any of these!!
Surely if it was the clifford, the ignition lights wouldnt come on?? They do come on!
Old Jan 22, 2004 | 06:10 PM
flashpoint's Avatar
flashpoint
How did this fault come to be
I have seen the same kind of fault on S2's with large intercoolers where the intercooler has worn through the wiring loom that runs across the box session, grounding the switched side of the coil
One-way of telling is to remove the king lead from the coil and turn the ignition on and off and see if you get one spark !!!
Check the integrity of the green wire from the coil to the ecu
Steve
Old Jan 22, 2004 | 07:02 PM
hello all. the car in question is mine and it does have a bigger intercooler, a GRS one. i have all the things listed above, but i have now resigned to the fact that it is probably something really stupid like a loose wire. methinks its time to call an autospark!
Old Jan 22, 2004 | 07:13 PM
Hope u get it sorted soon mr wilson!
Old Jan 22, 2004 | 07:16 PM
yeah then i'll smoke you!! and your da!!!!
Old Jan 22, 2004 | 08:00 PM
So u think,least both our cars start, hahahaha
Old Jan 22, 2004 | 09:25 PM
flashpoint's Avatar
flashpoint
Good luck mate
Old Jan 22, 2004 | 10:06 PM
Ahh skiman you simple fool, destruction of the subaru will occur when my car is running again
Old Jan 22, 2004 | 11:41 PM
WutangRS's Avatar
WutangRS
just out of curiousity does the cam shaft turn the distributer.
when mine knocked out the first thing i check was the spark and there wasnt any so i though no prob its an eletric fault.
this wasnt the case and was the symptons to a much larger story. belt had jumped causing the valves and piston contact and in the process snapping the cam shaft in the centre. result no spark or compression
Old Jan 23, 2004 | 01:18 AM
Thats if ur car EVER gets going!! U laughed at the bigshow when his ERST went off the road now its happened to you muwahahaha!!! And for ur info the subaru will not b beatin by ur rs!
DixieTheKid
11
Jun 6, 2020 11:20 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
