torque wrench settings
hi mate the setting 4 the mains all of these are from the haynes cvh rebild and tuning manual
main bearing caps 90-100 nm
con rod bolts 30-36 nm
flywheel to crank 82-92 nm
crank pully 100-115nm
that is for standard bolts if there arpones thay will habe the settings in the packet
hope thats a help if u need any more i have them all
cheeRS darryl
cheeRS darryl
i think even with dry bearings it will spin and also torque settings won't make the problem. It's more likely that one of your measurements went quite wrong. Wrong bearings i would say
