oil stem seals?????
Fleet Manager
oil stem seals?????
rights its a S2 ERST, got a little bit of smoke from cold start, hope its stem seals its 90k standard engine,
how difficult are they to change, cant find it in haynes manual.
oh and where can i buy the seals i have the tool already
hope its not piston rings
www.ctuceilings.co.uk
You don't want Ford ones, they are pants. I can't remember who makes the decent ones, I think it may be Piper.... Hold on, Piper make something decent??? Surely not
It may be your turbo that causes the smoke too, just so you know.
If it's only smoking from cold I would start with the stem seals. Go to Ford and get the one piece top hat type seal. You will also need a valve spring compressor. I would take all the spark plugs out to make turning the engine over by hand easier (you need to bring the piston you are working on to the top of its stroke to prevent the valve dissapearing into the combustion chamber). Also push a rag into the oilways of the valve you are working on as dropping a valve collet into the engine is a right fucker.
It should only take about 2 hours to do.
Be wary the car may struggle to start as oil is allowed to get into the chamber when the old seals are removed.
Fleet Manager
oh crap u mentioned the fatel word CEARFUL, i'll get some to do it, ive got the compressor, how much are they usually from ford???
yer its only on cold start, i look when im on load ans cant see smoke following me so hope this will sort it, its not rely using oil either
Somebody makes a modified version which is meant to be much higher quality.
Fleet Manager
blooming ell what should i do the car is never gonna be more that 200 break?????????????
tony if u remember who makes the aftermarket ones let me know plesae fella
other than that i think i'll just use standard stuff
I thought it was the two piece ones that were th naff ones to be avoided and that was why Ford revised them to th esingle piece top hat design.
Might be a million miles off though
That's why I said I think. Don't take my word for it, I play computer games for a living, ask someone who builds engines
But I have been told by several people not to get them from Ford.
I run the one piece top hat ones on mine and they seem fine
The job isn't very hard at all mate, as Oranoco says, remove the plugs and put a rag in the oil ways (i have a collet floating around in my sump ), and remember to do numbers 1 & 4 first, then spin the bottom end over 180 degrees and do numbers 2 & 3.
It's not very hard mate you should be fine
Oh and Oranoco ive had my pistons ABDC, the valves are just slightly too long to get lost
Well..............i did it intenionally. Long story cut short i did a LOT of work to the car, started it up and it was pissing out with smoke and i found a vlave guide had slipped down, so i thought i may aswell try the best i could before taking the head off, ended up cracking the guide so it came off anyway.
Definately wouldn't recommend it anyway just incase
Thats definately a good plan, the only thing you will find is some of the collets will be very tight and will push the valves open, where as normally you use the pistons to pop them free
07-10-2015 12:56 PM
