2wd cossie brakes
Don't ask - I don't know
No, in a word. 2wd calipers are 4 pots which won't fit under standard S1 rims. I run Escort Cosworth 4x4 calipers and 283mm 2wd discs. They go (just) but don't plan on having any stick on weights on the inside on the rim as then the rim won't clear the calipers as they rotate - it's that tight. But they WILL fit.
to make the 4 pots fit youll have to skim 3mm of the mounting face on the caliper. as for alloys i had a night mare trying to get some to go over mine. well worth it though
You've got to tap the bolts holes out with a M12 tap, and be careful when bolting them on as the bolts holes are fractioanally out, and for gods sake buy some high tensile cap head bolts to put them on with and nothing less!
03-11-2015 04:08 PM
FlashRS
13
31-08-2015 06:02 PM
Red_bull
09-08-2015 08:34 AM
