escort cosworth calipers
24-03-2006, 02:30 PM
Do these fit the s2 or can they be modified to fit... Was gonna get 2wd one off sierra but have been offered these at cheaper price..
Any one know ?
24-03-2006, 02:38 PM
yeah i have them on mine, pretty much direct fit IIRC, just need to space them out abit when used with 283mm cossie discs
24-03-2006, 02:42 PM
So no machining is needed then? Is it still the case if I have standard wheels? Whats IIRC?
24-03-2006, 02:47 PM
if i recall correctly
nah no machining just a 2mm spacer needed
24-03-2006, 02:49 PM
Ideal
How good are your brakes then with the cossie setup ?
24-03-2006, 02:51 PM
Ok then
Quote:
Originally Posted by thelynx
Ideal
His cars not fast enough to put any pressure on the cossie set up
24-03-2006, 02:52 PM
they're alrite, TBH i dont think the calipers are much better than standard RST ones, its just the fact that your upping the dia of the discs from 260mm to 283mm which makes it better braking
i am infact thinging of changing them to ST170 calipers & 300mm discs
oh yeah n they should still squeeze under your 15's but you cant go any bigger than that
you can get a adaptor plate so you can use your RST calipers with 283mm discs
24-03-2006, 02:53 PM
24-03-2006, 02:55 PM
davie you homo, go do something contructive.... is there no trains you can go play in front of?
Thats cool then, maybe stay with the standard calipers...
Any ideas on where to get the adapter plate from ?
24-03-2006, 02:56 PM
think "mad for it" do them, sure there over your direction as well
also check ebay, always see em on there
24-03-2006, 02:57 PM
Quote:
unchballs:
24-03-2006, 02:58 PM
Sweet, I drive past mad-for-it 3 times a week only ten miles from me
24-03-2006, 02:59 PM
lol well there u go then
since you fitting a big motor why not just do the ST170 brake set up?
24-03-2006, 03:02 PM
I didnt think they go under 15's
24-03-2006, 03:05 PM
Ok then
You will need a 16" rim for 300mm discs
24-03-2006, 03:09 PM
Well im trying to find the best braking set-up to fit under standard s2 rims
25-03-2006, 08:08 PM
i'm getting 2wd calipers for my series1 i've got 16 wheels on my car will these fit on ok and wot work is involved in gettin them on ?
26-03-2006, 11:08 PM
From what I understand is that you need to machine 3mm off the mounting face of the caliper to make them fit..
26-03-2006, 11:52 PM
im using 300 mm with the st calipers, works great for me, and my COMBI is fast enough to make them work too
27-03-2006, 09:08 AM
yeah soz lynx, forgot you were keeping it on std 15"
300mm wont fit then, stick with the 283mm disc
Vincereese
01-06-2023 09:14 AM
FlashRS
30-08-2015 08:07 PM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
Old ford
31-07-2015 06:50 AM
