500bhp
Old 01-04-2005, 07:27 PM
wilky
wilky's Avatar
Default 500bhp
what boost is needed for 500 bhp at 7000rpm
or would i need to increase the rpm to get the power?
Old 01-04-2005, 08:41 PM
wimwerf
wimwerf's Avatar
what engine? 2litre...2.2...2.3...2.4...
what turbo?
Old 01-04-2005, 08:42 PM
Dean-o
Dean-o's Avatar
if its the rover KABOOOOOOOOOOM
Old 01-04-2005, 09:06 PM
Rs Gus
impreza wrx sti version 8
Rs Gus's Avatar
all depends on turbo choice 30psi ish
Old 02-04-2005, 10:03 AM
wilky
wilky's Avatar
Default 500bhp
it will have gt3040r with a external wastgate
and it's a 2 liter
Old 02-04-2005, 10:18 AM
wilky
wilky's Avatar
Default 500bhp
the 620 still makes 292bhp at the wheel's for
2.5 year's and for a engine that cost's Ł600
what wheel bhp has your escort got for Ł600
it's a cheap car and i can surprise a few people
in it ,every one know's when you go down the
road in the escort and don't bother with you
[saying that i have,nt been out in the cossy for 2 mouth's ]
Old 02-04-2005, 10:06 PM
herb
herb's Avatar
My saff was 500bhp when on grey's at 29psi.
Old 03-04-2005, 01:24 AM
wilky
wilky's Avatar
Default 500bhp
what rpm was that mate and what size turbo
Old 06-04-2005, 12:02 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
In your fucking DREAMS . Greys run out of fuel at 440bhp (unless you mean 8 of them ) .
To achieve 500bhp at 7k on a 2 litre Cossie engine, you would need a T4 size turbo, and sufficient fuel (8 greens or 4 x 750cc injectors) and 30-32 psi depending on headwork / cam choice.
Old 06-04-2005, 12:37 PM
Dan
Dan's Avatar
What CC's are Grey injectors rated at then?
Old 06-04-2005, 01:51 PM
wilky
wilky's Avatar
Default 500bhp
i will be running 660cc at 5 bar the engine mapper
said this is enought [siemens disc injector]
my cam's are one off billet's made to cossy profile
they had load's off lift i had to machine the bucket's
to a bigger diameter
Old 06-04-2005, 03:12 PM
Mike Rainbird
Caraholic
Dan,
Just over 500cc at 3.5 bar.
Wilky,
That is a hell of a lot of pressure to be running at, you sure the fuel pump is up to that and won't cavitate ?
Personally, I would use a high flow pump and run it at a lower pressure....
Old 06-04-2005, 08:33 PM
wilky
wilky's Avatar
Default 500bhp
mike thank's for that i have got a uprated pump
i think it's a walbro i find out what the capacity it flow's
will any body know on here if i find out the number's on the side
of the pump
Old 07-04-2005, 10:52 AM
Mike Rainbird
Caraholic
Wilky,
You need to check that the pump is okay to run at that pressure, because don't forget that with a rising rate regulator, it will have to run at 7 bar (with 2 bar of boost) and it may shit it's load at that....
Old 07-04-2005, 12:09 PM
wilky
wilky's Avatar
Default 500bhp
sound's like i'am going to get in a lot of trouble.
i hope i don't have to make another fuel rail
an siemise my injector just made that lot last week
i think the mapper said it's 5 bar at full boost total
i have to find out
i need to run a remote fuel reg .do you know of a good
one to use as i have herd bad thing's about some after
market fuel reg's
thank's for any info mate
Old 07-04-2005, 01:13 PM
Mike Rainbird
Caraholic
The standard Cossie one is very good and is cheap as chips. Will run at 3.5 bar static fuel pressure all day long (which means it sees 5.7-5.8 bar on big power engines) . Avoid the FSE ones .
Old 07-04-2005, 01:36 PM
wilky
wilky's Avatar
Default 500bhp
thank's mate i will look out for a cossy fuel reg
cos elle
16-09-2015 06:37 PM
c6mby
186
16-06-2009 09:47 PM
wimwerf
18-06-2005 08:06 PM
AdsCapri2
28
08-03-2005 08:42 AM
Quick Reply: 500bhp
