any info for 500bhp YB engine
Hello,
A friend of mine wants a 500bhp engine......money is not really an issue....
I told him to get a GT30 turbo.....instead of a t38 he was told to use...
Is 500bhp possible with an intern wastegate.....
And what does such a turbo cost...because i dont know and he also...
He wants to use a swedish style inlet with 750cc injectors...
Could you tell me (him) what kind of spec/stuff he needs for this kind of power....
thanks for the help and info...
Regards,
Wim (and Sezer)
Regards,
Wim (and Sezer)
Just stick to the traditional T4 touring car route!
Grp A ported head
Secret spec cams
7.8-1 comp ratio
T4 @ 2.2bar
8 x greens on WRC manifold with eec4 escos plenum
Grp A fuel pump
A nice drivable 500bhp motor
Grp A ported head
Secret spec cams
7.8-1 comp ratio
T4 @ 2.2bar
Grp A fuel pump
Grp A ported head
Secret spec cams
7.8-1 comp ratio
T4 @ 2.2bar
Grp A fuel pump
A nice drivable 500bhp motor![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Grp A ported head
Secret spec cams
7.8-1 comp ratio
T4 @ 2.2bar
Grp A fuel pump
If you use the right cams and timing you will find a T4 not that laggy!
I just speak from ease tbh...if of course you goin dyno or live map then go overkill....
Autronic SM4
GT30
lairy cams
Swedish plenum
4 x 750cc
Twin fuel pumps
GRP A ported head
500bhp for most probably double the cost of my spec mentioned!..For what?..A little less lag!
Autronic SM4
GT30
lairy cams
Swedish plenum
4 x 750cc
Twin fuel pumps
GRP A ported head
DANISH cosworth abuser
Would go for gt-30R on an 2wd manifold, portet head, bd-14 or bd-15 inlet cam, sweedish style inlet as he uses now, 7,5:1 komp ratio, minimum 800cc injectors, BIIIIG cooler and proper engine management as haltech/NIRA/autronic aso.
THAT should se 500+ with good drivability
Originally Posted by wimwerf
Hello,
Regards,
Wim (and Sezer)
Regards,
Wim (and Sezer)
It is not hard at all.
Danielbetty
03-10-2015 06:01 PM
Hellraiser
30-08-2015 10:29 AM
