DIS converted cars / rev counters ????
i have converted my car to wasted spark ( coil pack )
but now the OE rev counter shows half engine speed , how have any of you got round this, dont want to fit aftermarket gauge ????
Originally Posted by Damo V
Or just fit a RS2000 / XR3i rev counter mechanism
( dials was from a late 1.8 XR3i )
worked on mine!!!
you cant use the original green trigger wire though, you have to use one wire direct from pin 1 (IIRC) of one of the ign amps alone
And mine!!
worked on mine!!!
ahhh thats prob why its not working then , will give it a go and let you know, cheeRS for the info
R U sure of that??
I though with the dizzy you get 2 pulses each turn and only one with the coilpack as you have two amps.. and that's why the tach shows only half the real engine speed??? (as the tach is plug from the - of the coil from factory)
I am also looking into this, the rev counter that works, does it have to be from a RS2000 or XR3i or will one from a Mk5 coil pack car work?
Also what car is the coil pack from Mk5 cars?
Has any one got any pics of this fitting placement of the coil pack?
Gav
Gav
cozzy jeff
14-08-2015 05:46 PM
CabrioTurbo
01-08-2015 11:04 AM
