ignition ???????
Old Nov 5, 2005 | 06:57 PM
JayRS2000's Avatar
JayRS2000
Default ignition ???????
what can i do next??
u all know im having trouble at the mo with the car it seems now its due to ignition and no spark ive now bought new sparks new leads new coil dispritor rotor arm theres no spark from the sparks and theres a 12v cummin from the ignition coil so im stuck to where this problem is????
anyhelp would be sweet cheers jay
Old Nov 5, 2005 | 07:32 PM
davidreader5's Avatar
davidreader5
HI,
If the wiring is ok, its either the dizzy, or ecu, as if everything is
working as it should the ecu senses vacuum from the inlet manifold
which is translated by the ecu (internal transducer)
takes engine speed from the dizzy (trigger pulse's)
and from temperature signals gives the correct spark including dwell
angle, the ecu also controls boost and retards the ignition timing
if air temp etc to high, so is really wiring, coil, dizzy, ecu.
if it turns out you need a ecu is it s1 or s2 as i have std ecu's
and what year, i also have a as new the internals for the dizzy,
easy fit just a couple of srew's, mine is available as i have cosworth
management,
DAVE R.
Old Nov 5, 2005 | 07:45 PM
JayRS2000's Avatar
JayRS2000
sound mate its lookin more like the ecu then
ive got a series 2 turbo mate
what would u bee looking for a ecu ?
cheers for ya help mate
Old Nov 5, 2005 | 08:49 PM
JayRS2000's Avatar
JayRS2000
anyhelp lads???
Old Nov 6, 2005 | 11:17 AM
rs_daz's Avatar
rs_daz
Theres a sensor in the dizzy it could be that.. i had same prob .if u got a m8 with a s2 see if u can borrow the dizzy try it ..
Old Nov 6, 2005 | 11:26 AM
antony215's Avatar
antony215
Escort Rs Turbo
As above change the distributor it's a common problem on the rs turbo's
Old Nov 6, 2005 | 12:52 PM
rs_daz's Avatar
rs_daz
I brought the sensor was about Ł40 easy to fit ..
Old Nov 6, 2005 | 02:49 PM
davidreader5
JAY,
What year is the car and on the ecu what colour or symbols are
on it the silver ecu,most will fit but need to check if knock sensor
on yours so say what year and if possible colours ie blue red white = s2
blue red & black = s2 with knock sensor etc,
if it is the dizzy like i said is easy fit and i have one new, when i
have your info on ecu i can say if i have one as i have several
ignition and fuel ecu's, is yours chipped as mine are all std,
so you could still use it with boost reset and co% and fuel pressure reset,
or just have your chip put into the std ecu, i will send a PM to you for
any prices for ecu and dizzy trigger assembly.
DAVE R.
Old Nov 6, 2005 | 03:20 PM
kossie's Avatar
kossie
I couldnt get a spark in mine for best part of 2 and a half weeks. Ended up putting a live to the same pin on the ECU that the black wire from the coil goes to, i think its pin 13.
Daniel Howard
17
Sep 26, 2015 12:39 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
beller
Sep 21, 2015 04:13 AM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
