Chips engine build
Old Nov 3, 2005 | 08:41 PM
Default Chips engine build
Copy of a post i made in repsonse to a question about my engine spec in general section, thought it might interest a few people here too so have copied and pasted it:
Steel motorsport crank
Steel rods
Forged low comp pistons (8.2:1)
Hotter (than calibra turbo std) cams, on vernier pulleys
Double valve springs
Solid valve caps
Garrett GT35R
Autronic SM2 management
Tubular manifold
Block has been destressed by hand by me with files and die grinder
Line bored, then the bottom skimmed referenced to the bearing tunnel then the block top skimmed relative to that, so that when it was bored i could guarentee it was exactly perpendicular to the crank
Head has:
21-4n steel waisted stem inlets (+1mm oversive)
21-4n steel exhausts (+1mm oversive)
ported to my specs with nitrous use in mind
Wizards of nos nitrous kit with maximiser controller
I'll be making 500bhp ish, and attempting to put it to the road by a 6 speed gearbox in FWD format.
Silly keeping it FWD really, as would be a 9 (or certainly 10) second car too probably if i went mid engined, but to me its kind of not really a mini any more then, and i wanted to built the ultimate (for me, obviously everyone likes different things) mini without it stopping it driving like a normal mini.
Still very much a work in progress, but here's a few shots of it so far:
head and valves:
approx how it will look assembled (i just put it together to check clearance between the manifold turbo flange and the block, its not bolted up yet here as i'm still working on the head at the moment)
The oil squirters ive installed in the block, as unlike a cossie it doesnt have a spray bar as standard so ive had to invent my own method for doing that (with some advice from Stu@MSD and ACDodd from ML motorsport)
Random picture of the block:
Some of the destressing work:
Before:
After:
Piston and rod:
Old Nov 3, 2005 | 08:52 PM
xr-stu's Avatar
xr-stu
thats going in a mini......fwd.........
Old Nov 3, 2005 | 08:57 PM
Yes mate it is going in a mini.
A stripped one, as light as i can get it while still be road and track useable.
Hopefully be around 600kgs dry, 800 with me in it and full tank of fuel etc, and should be making around 400bhp@wheels.
Giving it a power to weight ratio fully laden of 500bhp per tonne @ wheels.
Thats approx the same power to weight at the wheels as a normal road weight escos would be with 850-900bhp or so, just to put into perspective what it should be like from 60-120 etc where grip and aerodynamics arent so important as they are during a launch or top speed run.
Old Nov 3, 2005 | 09:11 PM
CliffRS4's Avatar
CliffRS4
Fair play to you Chip
Will be keeping an eye on this one
Old Nov 3, 2005 | 09:15 PM
Hopefully be out and about in it in 2007 some time
Old Nov 3, 2005 | 09:28 PM
PAUL V's Avatar
PAUL V
Chip how does grinding the block the way you have done destress it and why do you feel the need to do this ?
Old Nov 3, 2005 | 09:32 PM
Removes potential stress raisers.
The more important bits are the bits you dont really notice in the pics, like around where the bearing tunnel was line bored radiusing off the machined edges, some of the other stuff like taking the casting lines out the block isnt really needed, but its nice to have a smoother surface, easier to keep clean (and more pleasing to the eye )
Old Nov 3, 2005 | 09:38 PM
PAUL V's Avatar
PAUL V
I thought as much all for show, I have never seen a engine stress crack in the lower part on the block.
Nice job though, i fitted a T3 to a let on DTA in 1997 it was one of allans 1st Euc.
Good luck with it all
Old Nov 3, 2005 | 09:41 PM
Im a tart at heart
Cant beat a nice bit of engine porn
As i said though, around the bearings it actually IS important, they do fail at that point sometimes on the bigger power motors.
If i was putting it in a heavier car where it would see more strain i would have fitted a girdle to it as well to be honest, but it will never see full throttle for long enough in a mini for it to be an issue with fatiguing it hopefully!
Old Nov 3, 2005 | 09:42 PM
Any pics of the engine you built mate?
Sounds interesting, espeically that far back!
Old Nov 3, 2005 | 09:43 PM
PAUL V's Avatar
PAUL V
Have you seen that yellow KAD mini wiht the 16 valve XE motor in it ??
Old Nov 3, 2005 | 09:48 PM
Yes mate, seen that, awesome bit of kit (well one im thinking of was white and yellow IIRC?)
Someone you know?
Old Nov 3, 2005 | 10:00 PM
PAUL V's Avatar
PAUL V
Yes i have a lot to do with the car back in the day 1998 ? it is a kas space frame with a 2ltr 297 bhp XE motor in it.
Bill solis took it ou on it 1st run a mallory park for Car and Car convershions. It was built to run the fastes mini in the world race wich it won 1 but the next time aound BMW brought a new mini with a M3 Engine in it and sort of won
Very quick and light car around 500 kg if i rember.
Got some photos of my old engine, give me your Email Address and i will send them to you.
Yes it was back in the day when lost of pepole where claming 300 brake from a KKK Let with a Std ECU and std fuel pump
Old Nov 3, 2005 | 10:10 PM
Wow, very interesting stuff indeed mate, 500kgs is incredible too, especially with a fairly heavy engine in it, i take it that was on an F20 but a quaiffe gearset or similar then as a stnadard box wouldnt last 5 mins at that level of abuse IME!
chip@miniracing.co.uk
Old Nov 3, 2005 | 10:17 PM
PAUL V's Avatar
PAUL V
Strate cut F20 with a Harry Hocklay Groupe A gear kit and ZF plated diff.
Space frame carbon fibre body, KAd alloy rear arms Very Very light
Always remembr it had Yam RD discs on the rear and 2 pot calipers that is how light it was. It also ran on a DTA
Old Nov 3, 2005 | 10:23 PM
Yeah ive noticed quite a few of the REALLY light mini lads using motorcycle rear disks on their cars.
Ill probaby just go for a set of alloy radius arms and KAD rear disks for mine, i want it light, but not obsessively so, its mainly a road car at the end of the day and its a full steel body not a space frame too, so subtley different class of vehicle, its never going to be a competition weight wise against something like that!
Old Nov 4, 2005 | 07:17 AM
Old Nov 4, 2005 | 09:44 AM
adamS2RST's Avatar
adamS2RST
Old Nov 4, 2005 | 03:30 PM
essexrsturbo's Avatar
essexrsturbo
love it!
Old Nov 4, 2005 | 03:35 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Good work Chipolata
Old Nov 5, 2005 | 11:25 AM
James-W's Avatar
James-W
Wow should be mental. What 1/4 mile time you hoping with it been fwd?
Old Nov 5, 2005 | 03:11 PM
Stu @ M Developments's Avatar
PassionFords Creator
Impressive project
Old Nov 10, 2005 | 04:16 PM
Beach's Avatar
Beach
Cant wait to see this one go
Old Nov 10, 2005 | 08:21 PM
Mr C's Avatar
Mr C
impressed
What tools and bits did you use to do your oil ways, block etc, what heads did they have on
Old Nov 19, 2005 | 08:42 AM
Originally Posted by Mr C
impressed
Just a drill to make the hole mate (got a friend who is an engineer to make me a drill bit exactly the right size for a really good interference fit)
Then a die grinder to slot the block behind the bearing to feed the squirter.
Old Nov 19, 2005 | 10:59 AM
Red16's Avatar
Red16
loooking good chip
did you grind the bearing surface for the feed to the spray jets before the block was line bored ?
Old Nov 19, 2005 | 11:51 AM
James-W's Avatar
James-W
Fookin fair play any pics of the car its going in.
Old Nov 22, 2005 | 04:53 PM
Originally Posted by Red16
loooking good chip
No mate, it was done after, which is less ideal really, but i hadnt decided on doing it at the stage it was line bored.
We have checked its still round though and it is, so no harm done
Old Nov 22, 2005 | 04:55 PM
Sorry, very hard to see much of the rose jointed suspension etc in this picture, its a bit too dark.
Old Nov 26, 2005 | 01:57 PM
Charlie Chalk
Unknown.
I hope your leaving it that same colour....
And i wanna see it on reverse rims, M'tash grill etc etc
Old Nov 26, 2005 | 03:23 PM
luke89's Avatar
luke89
Team HOTHOT!
lookin good mate ( and im not on about u ) should be fucking mad
Old Nov 27, 2005 | 12:00 AM
coolamasta's Avatar
coolamasta
As said on MIG, nice work mate, should be one of the finest LET's built and the fact its going in a mini really says you are a nutter but fair play
Old Nov 27, 2005 | 12:30 AM
CliffRS4's Avatar
CliffRS4
More updates
Old Dec 1, 2005 | 03:14 PM
skylineboy2002's Avatar
skylineboy2002
Old Dec 1, 2005 | 06:04 PM
Originally Posted by Cliff S1
More updates
Well ive just arranged to buy a GT35R turbo for it, should be getting in a few weeks hopefully.
And im probably getting a different manifold made for it as im not confident the one i have can flow enough gas for 500bhp+
Radders, will be an extended clubman front, it doesnt even fit under a normal clubman and ive no chance of a roundnose.
Going to have to make the front about 4" longer i guestimate.
Old Dec 1, 2005 | 06:19 PM
CliffRS4's Avatar
CliffRS4
GT35 that's a bit serious
Old Dec 12, 2005 | 02:15 PM
Yeah, should be good for 550bhp or so hopefully.
Although TBH im not bother if it falls a bit short of that, as ive still got the nitrous on top anyway if i need it.
Old Dec 12, 2005 | 03:06 PM
Charlie Chalk
Unknown.
I understand now seeing the size of the turbo
Shame you cant have it the old retro look...
Oh well
Old Dec 13, 2005 | 09:08 AM
Oh well
LMAO
All seems a bit more obvious when you've seen my GT35 up close and personal.
You go and pop your bonnet and see how little clearance there is for stuff like the distributor on the little tiny 998cc engine and it starts becoming obvious that a 2 litre engine with a fapping huge turbo hung off it just isnt going in there and it all still looking factory
Old Dec 13, 2005 | 02:27 PM
Charlie Chalk
Unknown.
Still im loving the C16SE Conversion
As you said, Looks Factory
