FAO All The Experts , Help Needed
Old Sep 17, 2005 | 02:51 PM
Mr Brannen's Avatar
Mr Brannen
Default FAO All The Experts , Help Needed
My mate has converted his saff into 4wd and he is getting a wobble from the front end , he has new 2.9 XR 4x4 shafts in and was informed by PJ Motosport that they are fine, thinks it may be a gearbox mount , can anyone shed any possibilities on this, Bosch Man , Chip etc .....all the Techies your help would be greatly appreciated
Thanks Mr Brannen
Old Sep 17, 2005 | 03:25 PM
Mr Brannen's Avatar
Mr Brannen
Old Sep 17, 2005 | 03:55 PM
benporter's Avatar
benporter
Change the subject
Old Sep 19, 2005 | 06:31 AM
Mr Brannen's Avatar
Mr Brannen
Old Sep 19, 2005 | 09:02 AM
Mr Brannen's Avatar
Mr Brannen
Old Sep 19, 2005 | 10:08 AM
Stealth Bomber's Avatar
Stealth Bomber
Sling the damn thing on the Bay and buy a proper 4x4 Saff instead
Old Sep 19, 2005 | 12:24 PM
Mr Brannen's Avatar
Mr Brannen
Erm any other suggestions,
Old Sep 19, 2005 | 06:00 PM
SeanT's Avatar
SeanT
what sort of wobble?
a scary doesn't go round corners sort of wobble?
which ARB has he used and what washers on the compliance bushes?
I'm having an issue with having the wrong washers on the end of the ARB at the minute, and am also aware of a problem with 2WD arbs and 4wd cars (it changes the handling rather scarily)
Old Sep 19, 2005 | 08:10 PM
benporter's Avatar
benporter
We beged him not to convert it
any way it drives and handles fine,is a side to side type of shuder when pulling away wich goes at about 20-30mph
Old Sep 19, 2005 | 08:18 PM
Dragon's Avatar
Dragon
The gearbox top mount can go but it only normally creates a knocking sound going over bumps...
...are they brand new shafts? A knackered CV joint can cause wobble.
Old Sep 19, 2005 | 08:24 PM
benporter's Avatar
benporter
wont be new shafts,il sugest cv joint
Old Sep 19, 2005 | 08:58 PM
Dragon's Avatar
Dragon
I would go with CV joint straight away, especially with the symptoms you've described and the fact the noise goes away once moving (a damaged CV will make the shaft work elliptically rather than symetrically, i.e: throws it out of balance, causing it to wobble).
Put it on full lock (L and R) and turn the car around - if it knocks on one side you've solved the problem.
HTH.
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
