zetec fuel rail
Old Aug 14, 2005 | 01:09 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default zetec fuel rail
i was puting together the inlet side today using astra sri fuel rail frst injectors on std zt inlet the idel speed controll vale fouls on fuel rail any one know way past this,i thought about mounting on rear of manifold could this b the answer? also no one has replied to my last post about fitting manifold studs that go into oil ways can someone help!!!!!!!
Old Aug 14, 2005 | 01:51 PM
tonyturbo's Avatar
tonyturbo
if the idle control valve is fouling the fuel rail you could mount it on the back of manifold or remote mount it on the inner wing somewhere(i have just the thing). i was told you could use the vauxhall fuel rail but i'v never tried it. use somthing like jb weld etc for the studs. will be fine.
Old Aug 14, 2005 | 02:46 PM
pee vee's Avatar
pee vee
dont odd kid creations do a plate to convert the inlet manifold to the zetec head?
i know i wouldnt drill holes in my cylinder head.
Old Aug 14, 2005 | 03:05 PM
tonyturbo's Avatar
tonyturbo
y not? whats the difference? some people would rather waste money buying stuff they dont need. its only a zetec head. not like they r worth much.
Old Aug 14, 2005 | 03:18 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
hey tony hows it going finaly got engine out car and stripted down got the astra fuel rail looks good just that idle controll valve,what do you mean run it remote mount,by linking up pies?by the way just going for d comp plate got 2.5mm copper plate looks okay what do you think of them
Old Aug 14, 2005 | 03:21 PM
tonyturbo's Avatar
tonyturbo
run a pipe from inlet to valve and run a pipe back again. u know what i think about d comp plates. d comp plates are ok. some people are lucky with them and some folk have nowt but trouble. good luck. you still wantin my ofab ecu???
Old Aug 14, 2005 | 03:24 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
yes mate still wanting ecu do you ever work through edinburgh direction?
Old Aug 14, 2005 | 03:26 PM
tonyturbo's Avatar
tonyturbo
not really. furthest north we get 2 is glasgow. i'l post it if you want?
Old Aug 14, 2005 | 03:28 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
what about payment?
Old Aug 14, 2005 | 03:29 PM
tonyturbo's Avatar
tonyturbo
send a cheque or a postal order.
Old Aug 14, 2005 | 04:02 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
ok will get of nxt mnts wage if thats ok with u
Old Aug 14, 2005 | 04:59 PM
tonyturbo's Avatar
tonyturbo
aye fine.
Old Aug 15, 2005 | 12:28 AM
richm's Avatar
richm
blank off the idle valve position on the manifold and use the remote mounting block arrangement with hose connections as used on some EFi CVH cars.
Old Aug 24, 2005 | 10:04 PM
16vzetec's Avatar
16vzetec
as above
Old Aug 26, 2005 | 08:56 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
thanks guys going to do that this week
Old Aug 27, 2005 | 12:23 AM
tonyturbo's Avatar
tonyturbo
do you have the bits to do it? i have if you want them?
Old Aug 27, 2005 | 12:28 AM
Avinitlarge's Avatar
Avinitlarge
I used a std zetec rail with nissan skyline GTS injectors, No problems with the ISCV
Old Aug 27, 2005 | 03:52 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
looks good m8 what spec is the engine?thanks for info but already chopted the rail have to stick with top fed.
tony i was going to use a plate drill+tap + use bleed nipples what do you think
Old Aug 27, 2005 | 11:37 PM
tonyturbo's Avatar
tonyturbo
bleed nipples not big enough. need to be about 10mm internal diameter iirc.
get your mate with the welder to weld up the original holes for iacv an re drill 2 holes at back beside act sensor somewhere. if you have a pillar drill you could drill out 2 bolts so as you are just left with a threaded tube. tap holes in back of inlet to suit. screw tubes in and put a nut on them to tighten up. jobs a good un. or if poss get him just to weld on 2 alloy stubs.
Old Aug 28, 2005 | 10:15 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
any picts tony?
JK12
33
Apr 26, 2021 12:09 PM
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 27, 2015 04:55 AM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
