zetec head bolt settings for use with d comp plate
Old 27-08-2005 | 04:53 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default zetec head bolt settings for use with d comp plate
just wondering what torque settings are for 1.8?
is it differant settings for using d comp plate,thanks tommy
Old 28-08-2005 | 09:15 AM
richm's Avatar
richm
just use standard setting with the plate - sorry don't have the figures to hand..
Old 28-08-2005 | 10:13 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
thanks rich another q if u dont mind sealing plate to block i am using curil T sealing compound suplied by supplier how did you put it on(eg brush or just speaded out?thanks tommy
Old 28-08-2005 | 10:27 AM
richm's Avatar
richm
either way - just enough to get an even coating, there should be minimal gap filling requirement if the faces are flat and smooth, so a consistent thin layer is all you need. Any excess will end up getting squeezed into the oilways, bores, boltholes etc which you need to avoid as far as possible.
Old 28-08-2005 | 10:32 AM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
cheers rich just waiting on head gasket turning up at dealer,should hopfully get done this week thanks for advice
3i Jim
20-11-2015 05:12 AM
JoeyBoyden
20
22-08-2015 03:23 PM
ekjim
17-08-2015 08:57 PM
xr4x4rs
06-08-2015 09:03 PM
MadsBL
Wheels and Tyres
06-08-2015 10:04 AM
Quick Reply: zetec head bolt settings for use with d comp plate
