Brake biasvalve (rear), same as "brake line lock"?
Old Aug 12, 2005 | 01:37 PM
cozzie4d's Avatar
cozzie4d
Default Brake biasvalve (rear), same as "brake line lock"?
Hi all,
The brake biasvalve of my saff 2wd (tube looking thingie near the rear axles) is leaking, so broken. Therefor I want to remove it with a new one.
Now I found a "brake line lock, M10 connections".
Can someone tell me if this will work without changing a lot of things?
Here's an image from the burtonpower site where I found it:
Old Aug 15, 2005 | 02:13 PM
cozzie4d's Avatar
cozzie4d
anyone?
I'd really like to know, because a need to buy a new one soon
Old Aug 15, 2005 | 11:03 PM
jaimesdna's Avatar
jaimesdna
id like an answer to this 1 to as ive got the same problem. can the bias valve thing have the seals replaced?
Old Aug 16, 2005 | 09:33 AM
sailorbob's Avatar
sailorbob
They are not the same thing. The line lock is simply an on/off valve in the hydraulic line.
Old Aug 16, 2005 | 04:18 PM
cozzie4d's Avatar
cozzie4d
Thanks for the reaction. We'll have to go look somewhere for the right thing then.
I'm not near my car now, so I don't exactly now what it splits,
I believe it splits the the front and back-brakepressure.
Old Aug 21, 2005 | 09:46 AM
FoSiCo's Avatar
FoSiCo
The brake bias valve for the ABS system is mounted on the ABS unit.
You probably mean te 3-way connection above the rear-axle which splits the rear brake pipes
Get it from Ford, it's the same for all Sierras and should set you back about 10,- euros
Old Aug 22, 2005 | 03:17 PM
cozzie4d's Avatar
cozzie4d
The guys at the Ford dealer told me a price from around 120 pounds, probably some misunderstanding. I'll take a pic of mine under the car and put it up.
Old Aug 22, 2005 | 03:49 PM
sailorbob's Avatar
sailorbob
There isn't a 3 way connector on ABS equipped cars, each caliper is independantly connected to the ABS valve block.
We'll know what you are talking about with the help of the photo.
Old Aug 22, 2005 | 05:45 PM
jaimesdna's Avatar
jaimesdna
there is deffo a 3 way connector on ther rear of cossys. they only have 1 brake line to the rear then split 4 each side. the part cozzie4d is talkin about is called the rear brake pressure reducing valve. its located over the top of the main beam & it is infact Ł120 from ford allthough its no longer a part that for can get hold of. when my car comes off the road at the end of september im gonna take mine off & see if it can be rebuilt
Old Aug 22, 2005 | 08:51 PM
PAUL S's Avatar
PAUL S
On 2wd cars the reducing valve is by the rear beam, but on 4x4 versions its right under the valve block in the right hand side of the engine bay instead
I have a good spare one if anyone wants it Ł15 plus post
Old Aug 23, 2005 | 10:25 AM
cozzie4d's Avatar
cozzie4d
Sounds good mate, tonight I'm at the garage and I'll make a picture, just to make sure it's the right part. Can you hold the spare one till tonight?
Old Aug 24, 2005 | 06:25 AM
cozzie4d's Avatar
cozzie4d
Finally been able to take some pictures of the brakelines.
The part that's broken doesn't split the brakeline to left and right, it's one way in and one way out (I have no idea what it does...)
This is the part thats broken:
and this is the part thats NOT broken (although it looks crappy ):
Old Aug 24, 2005 | 09:29 AM
sailorbob's Avatar
sailorbob
They look like rear brake compensators, usually these are a fixed calibration and not load sensitive. I can't believe they are Ł120. Someone must know of a different source to Ford.
Old Aug 24, 2005 | 09:22 PM
cozzie4d's Avatar
cozzie4d
Does anyone know a source or even know what it's exactly called?
Old Aug 25, 2005 | 08:29 PM
jaimesdna's Avatar
jaimesdna
yer, its called a rear brake pressure reducing valve
Old Aug 25, 2005 | 08:32 PM
cozzie4d's Avatar
cozzie4d
Thanks mate, I just pm'd with a.k.a., and arranged to buy his spare one.
Thanks everyone, problem solved
Old Sep 2, 2005 | 08:41 PM
DOO's Avatar
DOO
these vaule did cost about Ł136.00 but arte no longer avab from ford part number 1637851
Old Sep 3, 2005 | 08:31 AM
cozzie4d's Avatar
cozzie4d
True.. that's what the Ford dealer told me I think.
Got myself a used one, in good condition. Now let's hope it stays good
Old Sep 13, 2005 | 04:10 PM
rocky_robin's Avatar
rocky_robin
Anyone got another one of these valves??????
Mines is leaking also (3dr)
The term meaning pressure reducing valve, does it leak off excess fluid, through the small hole???
Please help!!!!
Old Jul 4, 2009 | 01:52 PM
Harris.'s Avatar
Harris.
Very old thread i know ,but mine is now leaking and i need a new one . anyone on here have one ?
Old Jul 4, 2009 | 02:19 PM
RONNIE AMIS's Avatar
RONNIE AMIS
just use a ka or a new fiesta one
Old Jul 4, 2009 | 05:09 PM
As said just use another ford one, with rear discs though.
Old Jul 5, 2009 | 08:24 AM
Harris.'s Avatar
Harris.
Ok i will look out for one ,cheers
JK12
33
Apr 26, 2021 12:09 PM
3drRich
Sep 13, 2015 07:32 PM
hopper350
Sep 4, 2015 12:53 AM
borboyous
Aug 22, 2015 11:17 AM
Red_bull
Aug 9, 2015 08:34 AM
