Help required to set up stage 3 saff on closed loop
Visitor from the Darkside
I have been trying to get the car set up for a while now and seriously thinking about a trip to Blackpool but it is a wee bit far. I could not get the boost to rise above 14 psi until Stu
advised me there was a restrictor in the Amal valve. I drilled this out .5mm at a time and was getting the boost up. I got it to 22psi peak and dropping off but then I got the chance of getting the bumpers painted so it was tucked up in the garage for a while. All I have done meantime is change the oil and filter and put on some Samco hoses and now I cannot get the car to boost more than 18 psi.
Now I am really sad and wondered if anyone could help me with any suggestions. Is the car safe to run 18 psi just now? I remember Stu's post stating if the tuner says to set it at 24PSI then thats what it HAS to be set at.
Please help me ?
advised me there was a restrictor in the Amal valve. I drilled this out .5mm at a time and was getting the boost up. I got it to 22psi peak and dropping off but then I got the chance of getting the bumpers painted so it was tucked up in the garage for a while. All I have done meantime is change the oil and filter and put on some Samco hoses and now I cannot get the car to boost more than 18 psi. Now I am really sad and wondered if anyone could help me with any suggestions. Is the car safe to run 18 psi just now? I remember Stu's post stating if the tuner says to set it at 24PSI then thats what it HAS to be set at.
Please help me ?
i think the best thing to do...........is drive the fooker to stu and get him to sort it out
this is not a bolt on conversion we are talking about here..........you want it right ...take the car to the bloke that knows
Originally Posted by Rick
could be the hot weather, not allowing it to boost. If it's one of Stu's chips, then it'll be fine at 18psi.
Originally Posted by pugo
i think the best thing to do...........is drive the fooker to Stu and get him to sort it out
PassionFords Creator
Graham,
One thing to check here is that the amal valve isnt actually faulty.
Do this by trying her out unplugged, the boost should drop substantially, if not, it may well have an intermittent contact.
Other alternatives are airleaks etc etc... not easy to diagnose from afar sadly
Dangerous springs to mind.
If it were my own car with closed loop, i would be trailoring the car to STU.
Whats the point in risking an engine for the sake of a 250mile drive?
Jus IMO
Jus IMO
If it were my own car with closed loop, i would be trailoring the car to Stu.
Jus IMO
Jus IMO
Originally Posted by Uncle Stu
Graham,
Thanks all
Graham
Jus IMO
Jus IMO
I understand what you mean about knowing what people change and check etc.. but if yo take it to Stu im sure he would give you the reason and explain how and why etc.. So you would find out in the end and know for next time
I do think you should check the engine bay for leaks tho. An easy way to do this is go to a tire shop and ask for a tire valve. Drill a hole in a plastic cup etc.. then fit the tire valve to the cup. Then place the cup into an end of a boost pipe.
If you use a normal bike pump and pressurise the system you will be able to find the leak.
