Cosworth tuning issues with 36-1 trigger
Old Dec 12, 2024 | 11:24 PM
wadec's Avatar
wadec
Default Cosworth tuning issues with 36-1 trigger
I have a 36-1 trigger tooth and 1 off dizzy that tuner can’t get working with link ecu. Problem is car won’t start consistently. Sometimes must switch off/on and crank a few times, may backfire on occasion. It’s electrical because when the car starts it starts instantly so there’s not point in cranking for more than 2 seconds. The tuner says it’s the 36-1 causing the issue it can’t pickup the teeth (may mean gap). He’s a very reputable, seasoned tuner and has tried all sort of changes and big measures to see if anything changes but it’s remained, and these cars are not common here. His solution is going back to 4 teeth with hall affect sensor on both trigger and add one to dizzy. Does this sound like a solution or is there a know reason the 36-1 doesn’t play well with this engine / setup?
Old Dec 13, 2024 | 02:21 PM
XR2's Avatar
XR2
Did you check the CPS output signal with an oscilloscope?
There's a lot of issues you can have with an aftermarket CPS setup.
1. Damaged CPS sensor unit
2. No shielded cable to the CPS, causing misreadings
3. Bad trigger wheel design
4. wrong distance between sensor and trigger wheel
5. Trigger wheel not centered properly on crankshaft
6. wrong type of input signal for the settings of your ECU
Plus depending on what type of injection/ignition you're running you need more than just the CPS signal, you need a camshaft position sensor and a correct setting/programming for your ECU.
scoobydooby914
Jul 26, 2011 11:34 AM
Rax
Jul 31, 2009 11:32 AM
Gary F
Ford Escort RS Cosworth
Sep 3, 2006 07:23 PM
Milko
Nov 24, 2003 02:35 PM
RS500/364
Oct 2, 2003 07:30 PM
