Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Water in the Boot.
Old Nov 15, 2023 | 06:59 AM
ageevt's Avatar
ageevt
Default Water in the Boot.
Others may have had this problem. I found a couple of gallons of water around the spare tire, down in that well.
Where is it getting in, and how do I stop it?
Old Nov 15, 2023 | 07:58 AM
XR2's Avatar
XR2
Which model?
Old Nov 15, 2023 | 10:18 AM
haz87's Avatar
haz87
If its anything remotely older its usually rear light seals. Of course I'm going to assume you've gone to the effort of identifying whether the boot seal itself is in good shape or not given it will have been right in front of you.
If its leaking so badly that you have a small swimming pool in the boot, the entry point/area should be fairly obvious and easily traceable - just run some water over the back for 30seconds, open the boot and you'll likely spot where its coming in.
Old Oct 1, 2024 | 02:35 PM
dhutch's Avatar
dhutch
On ours it was the seal sealant up near the boot hinges.
Old Oct 7, 2024 | 02:07 PM
rog's Avatar
rog
I’ve fixed a couple of these, the usual culprit is the mastic type sealant that’s in the boot shut at the end of the roof rail the 1/4 panel joins the roof, around the hinge and under plastic strip on the roof and they are absolutely notorious for leaking, just pull up the roof rail, clean out as much of the bad sealant as you can and then tiger seal it up and tiger seal the roof rail back down, job done. Obviously check around the rear lights, as well but I pretty much guarantee it’s the sealant being cracked beside the roof rail.
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
Martycul
Feb 2, 2013 06:31 PM
El Kevo
Jan 22, 2010 08:42 AM
adamski frst
Ford Escort RS Cosworth
28
Nov 7, 2005 10:08 PM
Clare
Escort MK 5 / MK 6
Dec 1, 2003 09:35 PM
