Wheels and Tyres Wheels and Tyres for all Ford's
Koni shocks. Wheel fitment
Old Dec 28, 2022 | 02:41 AM
Wolvesboy's Avatar
Wolvesboy
Default Koni shocks. Wheel fitment
Hi All, my 17 inch Ford wheels (7.5j ET38) won't fit past the spring base of the shock. I have 205x40 tyres and there is no way it is even close!!
What is everyone else using?
Old Dec 28, 2022 | 10:40 AM
BIG LEE's Avatar
BIG LEE
are you sure you usen all cosworth parts? mines running konis and ive got 8.5j x 18s on mine running 215/35/18.. before them always run 8x17s with 205/40/17 never had any problems
Old Dec 29, 2022 | 04:06 AM
Wolvesboy's Avatar
Wolvesboy
I bought them off a fellow Cossie owner who said he had them on his car! I am beginning to wonder.
What is your wheel offset? On my 17s it is 38
Old Dec 29, 2022 | 01:38 PM
Wolvesboy's Avatar
Wolvesboy
Angry
To clarify - these are the shocks I have fitted: Koni Adjustables with numbers 8741 1109 9202 stamped on them.
My Ford wheels are:
These wheels should fit as far as I am aware! Something is up here! I placed a metal ruler vertical on the face of the brake disc and measured from the spring seat and it was 115mm. As a rough guide, with 7.5 rims the centre line is about 90mm - that only gives me +25mm MAX. ET to play with before the tyre catches the shock. That does not sound right to me!
Old Dec 29, 2022 | 04:54 PM
BIG LEE's Avatar
BIG LEE
im not sure but someone here should know i think u need to run 5mm spacer for rs 7 spokes on front my sapphire had them on but with spacers
Old Jan 1, 2023 | 07:48 AM
christos's Avatar
christos
10 Year Member
I had 3mm spacers on my 4x4 sapphire cosworth but I replaced them with much lighter wheels due to big brake kit.
Old Jan 1, 2023 | 08:09 PM
qed296's Avatar
qed296
I ran 5mm spacers on the fronts when I had diamond cut rs7 spokes, to clear the caliper and the shock spring cup.
Have alook here when I first had the same issue with my splits.
https://passionford.com/forum/ford-s...-catching.html
Karl 3dr
Jul 13, 2011 09:44 AM
Kev83
Apr 4, 2009 11:09 AM
montecos400
Aug 19, 2007 02:27 AM
S3an
Ford Escort RS Cosworth
22
Sep 25, 2006 05:23 PM
